R50/53 Help out a suspension noob. What to buy?
Old Dec 9, 2011 | 02:34 PM
Minibeagle's Avatar
Minibeagle
I have a 2002 MCS with about 65,000 miles that still has the original suspension. I find the ride quality has degraded since last year and I think it's time to replace the struts and springs.
The MINI is in storage for the winter and I would like to have the suspensioin revamped in the spring.
I am a complete suspension noob and need some advice as to what I should be buying as replacement parts.
Here is some more info:
1) I would like to increase ride quality over what the original OEM suspension offers
2) I wouldn't mind lowering the ride a little, but it's not absolutely critical
3) My budget is kind of limited. I don't want to shell out serious $$$ for expensive coilver sets
So... what do you guys suggest?
Any and all suggestions would be greatly appreciated
Old Dec 9, 2011 | 02:50 PM
fhdogs's Avatar
fhdogs
I run Koni 1150 coilovers. I'm not sure what your limits are as far as $$$ but I'm very happy with them, the adjustability they offer, and the ride makes the money spent worth it. I usually run mine on the firmer side so passengers aren't so happy, but that all a matter of driver preference.
Old Dec 9, 2011 | 05:58 PM
element's Avatar
element
ride quality instantly increases with new shocks.. as the old ones wear down slowly over time and you dont really notice how bad it was.
If you lower the impact\number of times everything gets really compressed goes up.. it's sooooo worth it for the handling
phil.
Old Dec 10, 2011 | 05:01 PM
ScottRiqui's Avatar
ScottRiqui
The springs themselves probably aren't bad, and Koni FSD shocks are a nice improvement over the factory ride, especially on a 2002. With 65k miles, you almost certainly need new lower control arm bushings in the front - the factory ones are prone to wear and can give you kind of a "disconnected" feeling in the suspension. It would also be a good time to check/replace the front sway bar bushings, ball joints, and upper & lower engine mounts.
Old Dec 11, 2011 | 03:30 AM
HRM's Avatar
HRM
I think...
Non-runflats, the FSDs, and a rear sway bar will make you very happy. If the front end needs something it is probably LCA bushings.
Obviously if something else is worn you need that too, but as a ride quality upgrade, shocks, and regular tires will be astonishing to you.
Old Dec 12, 2011 | 09:33 PM
slocraiger's Avatar
slocraiger
if you have run flats; get rid of them!! that will be the biggest change
Old Dec 13, 2011 | 04:51 AM
Minibeagle's Avatar
Minibeagle
Never had run flats. Bought the car used in 2007 and have used non run-flats since in summer and winter.
I'm more interested in obtaining info on what brand strut / spring / coilover to buy to get better ride than OEM suspension that is still on the car.
Keep the suggestions coming. Thanks
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
Witsticka
Sep 15, 2015 01:33 PM
nomar116
Aug 10, 2015 11:24 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
