R56 Which Short Throw Shifter?
Old Nov 23, 2011 | 05:48 PM
germanguy's Avatar
germanguy
Im debating which short throw shifter i should get. Right now im contemplating between the Helix and NM adapters. Does anybody have experience with either of these? If so, which one is better? Any help would be greatly appreciated
Old Nov 23, 2011 | 05:52 PM
drewstermalloy's Avatar
drewstermalloy
CravenSpeed adjustable.
Old Nov 23, 2011 | 06:04 PM
tcscb1963's Avatar
tcscb1963
I have the Helix, very happy with it.
Old Nov 23, 2011 | 07:54 PM
germanguy's Avatar
germanguy
I was looking at that one, but from what cravenspeed said it doesnt reduce the throw, just the shifter length.
Old Nov 23, 2011 | 08:08 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Not true. If you look at how it works the fulcrum point for the shifter changes as you slide the center. The amount of how much shorter the throw is based on the length from the center of the ball, to the tip that the shift cable attaches to. That's how the adapters work, the just make that length longer, and therefore it takes less movement at the other end of the shaft to make the shift.
I like the Craven shifter the best, it makes the shifting very crisp even without adjusting it down.
Old Nov 23, 2011 | 08:40 PM
SOCALGUY2007MCS's Avatar
SOCALGUY2007MCS
I have had the NM adapter on my MCS for about 4 months now and love it. It keeps the shifter and the same level but does shorting the throw about 50%, well what i think it feels like. All the other short shifters actually just shorten the height of the shifter, thus reducing throw. I love the NM, but if you get the NM, make sure you get the cover for it. I used with out cover for about a month, and it added a little bit of noise to the cabin, also when i went to put the box cover on notice the linkage was really dirty. Hopefully this was helpful.
Old Nov 23, 2011 | 08:45 PM
gds194's Avatar
gds194
I also have the NM shifter with there cover. Real simple to install and works great!
Old Nov 23, 2011 | 08:49 PM
germanguy's Avatar
germanguy
How do the shifts feel?
Old Nov 24, 2011 | 07:27 AM
cop1406's Avatar
cop1406
I have the Craven Short Shift with the well cover. It is my favorite mod. Add the NM torque insert and the shifting is transformed to a thing of beauty and smoothness.
Old Nov 24, 2011 | 07:55 AM
JPMM's Avatar
JPMM
Cae
I would like to install one of these without tearing up the interior too much!
https://www.northamericanmotoring.co...-want-one.html
Old Nov 24, 2011 | 08:37 AM
germanguy's Avatar
germanguy
I saw that one, but it seems a little pricey for now. I think im going to buy the NM adapter for now
Old Nov 24, 2011 | 08:48 AM
JPMM's Avatar
JPMM
It looks like a bear to intrigrate into the interior, I would like someone that has done one to show how they put the console back together
Old Nov 27, 2011 | 11:48 AM
madmaxxed's Avatar
madmaxxed
I just installed the NM adaptor the other day. Install was a breeze. Since the exhaust was going to be pulled I installed the NM DP back exhaust as well. The NM adaptor is a really nice piece. I used a heavy strength red loctite on the set screws. I also bought the NM modified cover. I did remove the screws that came on the new cover and replaced them with metric stainless screws and lock nuts for added security. I am a real fan of NM Engineering. Great products.
Old Nov 27, 2011 | 06:12 PM
Porthos's Avatar
Porthos
I have the Alta one which is the same as the Craven minus the easy adjust-ability. Go with the Craven because the Alta one is not made anymore. Also Helix and NM are the same thing as each other.
Old Nov 28, 2011 | 07:50 PM
germanguy's Avatar
germanguy
Ive been starting to give the cravenspeed more thought. Does the cover need to be changed when you modify the length of the shifter? Kind of like the nm engineering cover
Old Nov 28, 2011 | 08:27 PM
Scooter09's Avatar
Scooter09
It depends on how much you adjust it. If you make the shifter really low, yes, but you can adjust it just to the point where you won't have to change the cover. Also, I don't know the dimensions of the NM cover, but if you make the shift REALLY short, it may not work inside the the cover boundaries.
Old Nov 28, 2011 | 08:31 PM
WayMotorWorks
Vendor
You don't have to install the cover, but it is nice to keep sound and heat from coming through the shifter housing.
Old Nov 28, 2011 | 08:43 PM
jrflurry's Avatar
jrflurry
I have the Helix and I love it. Super easy install and shortens the throw around 40% without having to reach down to your knee to shift. And speaking of knees I dont hit my passengers knee when shifting from 5th to 6th anymore!
elverado
Jan 18, 2022 02:51 AM
Pker
Apr 11, 2017 12:14 AM
Sep 22, 2015 02:05 PM
Rainforest_Elf
Sep 16, 2015 10:13 AM
Mb460
Sep 14, 2015 05:50 AM
