How many times can runflats be mounted?
Old Nov 19, 2011 | 06:48 AM
Vic Mackey's Avatar
Vic Mackey
I found a set used of Blizzaks near me. However they have been mounted twice before. How many times can they be mounted before the structure of the tire is damaged?
Old Nov 19, 2011 | 07:19 AM
fishey72's Avatar
fishey72
Runflat snow tires?
Did not know they even made them.
Last edited by fishey72; Nov 19, 2011 at 07:21 AM. Reason: Ahhh by the power of the internet corrected my assumption!
Old Nov 19, 2011 | 07:51 AM
Vic Mackey's Avatar
Vic Mackey
Originally Posted by fishey72
Runflat snow tires?
Yes they do. Here is a link : http://www.tirerack.com/tires/tires....20Valve%20Stem
Old Nov 19, 2011 | 08:57 AM
DneprDave's Avatar
DneprDave
You can mount and dismount tires as many times as needed. They are designed to be taken off and put back on, without damage.
Dave
Old Nov 19, 2011 | 10:27 AM
RJKimbell's Avatar
RJKimbell
Dave
That's what I would think, as with all tires, run them 'til you're down to the wear bars or you are not satisified that they are doing their job anymore!!
Old Nov 19, 2011 | 11:04 AM
WildThang's Avatar
WildThang
If the tires are changed correctly, mounting and remounting to the rim with a machine designed to handle run flats, as often as you need them changed. We use the Blizzak RFT here for the snows of the midwest. Ours just got remounted for the third time in the tires life. No issues, great tires.
silence2-38554
Nov 12, 2015 09:39 AM
tr3y003
Oct 22, 2015 10:48 AM
Colt45Magnus
Sep 7, 2015 10:47 PM
sabjcw
Aug 14, 2015 07:40 AM
