R56 when to replace belt?
Old Nov 17, 2011 | 08:53 PM
yyj3869's Avatar
yyj3869
mine 07 mini cooper non-s hits 58k now. do i need to?
Old Nov 18, 2011 | 05:36 AM
schatzy62's Avatar
schatzy62
What Belt?
Seat Belt?
Timing Belt? but this would actually be a chain
Fan Belt?
Serpentine Belt?
What are you asking info on?
Old Nov 18, 2011 | 08:21 AM
proximo's Avatar
proximo
General rule I follow is every time I change the oil is to examine the belts and twice a year to examine all rubber components (I do before winter and before summer). If I see any hints of cracks or extra wear, it's replace time regardless of mileage. But, if you're looking for the recommended replacement time, Schatzy62 has the ball with the right questions.
Old Nov 18, 2011 | 09:14 AM
yyj3869's Avatar
yyj3869
Originally Posted by schatzy62
What Belt?
Seat Belt?
Fan Belt?
Serpentine Belt?
sorry it's timing belt.
Old Nov 18, 2011 | 10:45 AM
Porthos's Avatar
Porthos
Tomorrow........
Old Nov 18, 2011 | 01:54 PM
Slave to Felines's Avatar
Slave to Felines
It's a chain, so the replacement interval is "during an engine rebuild". Or if there are problems with the chain and/or tensioner.
Old Nov 18, 2011 | 03:08 PM
schatzy62's Avatar
schatzy62
Not sure if MINI has a recommended change interval or not but some other cars i have owned with similar type engines had a 120k miles
Old Nov 18, 2011 | 07:17 PM
gixxerjasen's Avatar
gixxerjasen
When you hear a loud rattle, it's time to change it.
Old Apr 8, 2024 | 11:19 PM
2014MCS_Miami's Avatar
2014MCS_Miami
I just did my serpentine belt and it wasnt too bad. I ordered a generic version of the BMW special tool for $42 off of eBay. I did remove a bunch of stuff to gain access, and loosened the motor mounts to tilt the motor as needed. I also ordered a new tensioner and "deflection pulley" as I was told it was wise to replace those at 96k miles too. Uh...yeah, so those are IMPOSSIBLE to get off without either specialty tools or pulling the motor out of the car. I gave up on replacing those two items nearly right away and they're still sitting brand new in their boxes. New belt seems like it has good enough tension with the original tensioner still in there. Oh well.
As for the old belt at 96k miles, it actually surprisingly looked great, no cracks or anything.
Old Apr 9, 2024 | 10:58 AM
white46's Avatar
white46
I replace the serpentine belt when I was doing the timing chain at about 100k miles.
I don't think it was ever replaced before and it looked bad. Cracking everywhere.
At that time, I didn't replace the whole tensioner. Only replaced the pulley on the tensioner which cost so much less.
Old Oct 22, 2024 | 07:42 PM
Rogerbird1's Avatar
Rogerbird1
So with the 4 cyl, How do you replace the altenator? Do you have to pull the engine?
I barely got the tensioner off the belt, but could not get the belt out. just out of the way..
anyone remove the Altenator? help!!
iamcamkeenan
Aug 10, 2015 03:31 PM
Lt. Dan
Aug 10, 2015 08:23 AM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
