Navigation & Audio Please help with Bluetooth connection??
Old Oct 21, 2011 | 12:54 PM
XRAMX's Avatar
XRAMX
My 2007 MCS bluetooth has just stopped working. It no longer transmits a signal so the phone can see the mini in the bluetooth menu. My iPhone 4 has been working perfectly for over a year and then it just quit. I went to the dealer and we tested both my phone (on another MINI) and it recognized that one right away. We also tested several other phones and none were able to see my MINI. My MINI has stopped transmitting a bluetooth signature and the dealer said that they have no fix for this? I asked what they would do if the car was in warranty and they said they would replace the electronics.
Does anyone know of a way to reset the bluetooth?
Old Oct 21, 2011 | 02:57 PM
Minidrivr's Avatar
Minidrivr
Back in 07 there were threads here about the bluetooth module becoming full from repeated phonebook downloads and becoming fried. Not sure what happened with that.
One sample.
https://www.northamericanmotoring.co...024-post9.html
Old Oct 24, 2011 | 05:00 AM
schatzy62's Avatar
schatzy62
Doubtful that it is a overload problem as that only happened with a few certain phones and the iPhone was not one of them. And if that was the case it would have failed alot sooner
Now as for the dealer stating "there is nothing we can do" that is total BS as all they have to do is replace the Bluetooth Module. Easy as that.
Now as to whether you want to pay that kind of money is another question. It will probably run you over $1K to have it fixed.
Another cheaper option is to have a Parrot Bluetooth unit installed. They can be made to work with you steering wheel controls and play thru the radio just as your OEM did. The only difference will be that the contacts will not be on the screen in the speedo they will be on another screen that is dedicated to the Parrot system.
Old Oct 26, 2011 | 09:32 AM
alexs3d2's Avatar
alexs3d2
The dealer should be able to reset the Bluetooth module. They should also test the module with BMW's Service Software before concluding that a new electronics module is needed. It may very well be the Bluetooth antenna, which is not integral to the module. I am certain BMW must have a test plan in place to find the fault.
If you are certain you need a new MULF, then you may find good deals on the internet instead of going to the dealer. Since you have the cabling in place, changin the module shouldnt be much of a hassle. But you may need to code it later...
Old Oct 26, 2011 | 09:49 AM
alexs3d2's Avatar
alexs3d2
Oh Yes I forgot... You may want to try to remove the fuse for the MULF and headunit and so force a restart, but I doubt it will help.
Old Oct 26, 2011 | 01:45 PM
strobeyprobey's Avatar
strobeyprobey
Shouldn't need to code the replacement ULF if it is a used module. Mine didn't require it.
ISTA/P doesn't offer any way to reset the ULF as far as I know, maybe a software update (as long as one is available) could fix it.
Old Oct 28, 2011 | 12:14 PM
XRAMX's Avatar
XRAMX
How much did the replacement ULF cost. How hard was it to replace? Any instructions for this on the forum?
Thanks for the help! I am disappointed with the dealer for not knowing how to repair this.
Old Oct 31, 2011 | 07:34 AM
strobeyprobey
For me, I actually added the bluetooth system to my car. I really lucked out and got the module on ebay for $50. There is one right now listed for about $314 on ebay (270843532503). It is located under the driver seat, so you have to remove the seat and module itself has just a MOST bus fiber optic connector and a harness plug. Not too difficult if you have the right tools to get the seat out. Something like a T40 or T50 is needed.
Old Oct 31, 2011 | 10:42 AM
XRAMX's Avatar
XRAMX
Thanks for the info. Now that I know where the BT module is it will be much easier to troubleshoot or replace!!!
Filmy
15
Jun 6, 2023 06:27 AM
pglgp1292
Oct 5, 2015 06:47 PM
krohm
Sep 28, 2015 12:16 PM
dragonby
Sep 25, 2015 08:10 PM
rt808
Sep 25, 2015 01:59 PM
