R50/53 launching
Old Feb 9, 2004 | 10:03 PM
hondacivic's Avatar
hondacivic
Whats the best way to launch the MINI? for best performance.
thanks
Old Feb 9, 2004 | 11:19 PM
The_Beastmaster's Avatar
The_Beastmaster
Dump the clutch at 3500, but I wouldn't do this too often.
Old Feb 10, 2004 | 12:15 AM
rfibanez's Avatar
rfibanez
Try slipping the clutch too...and dont rev too much when u launch or you'll just spin youre tires.
Old Feb 10, 2004 | 12:50 AM
weaverpsu's Avatar
weaverpsu
just practice, you'll get it!
Old Feb 10, 2004 | 02:10 AM
TwOMINIs's Avatar
TwOMINIs
Strap a couple of these guys to the back end.
His, Chile RED over, Madness intake, Magnaflow exhaust, Helix 15 % Pulley & RDR Swaybar
Hers, Electric Blue / Union Jack on top and BONE Stock
Old Feb 10, 2004 | 02:22 AM
jsun's Avatar
jsun
It also depends on whether you have CD36 (or above) software. In my 3 previous versions -- 32 and several 33's -- I had stumble and over-aggressive traction control. These definitely impacted how one "launched" the car in that considerable attention needed to be paid to slipping the clutch and/or revs. Now, with 36, I just drive away like any other car....and I don't have to remember to turn my traction control (integrated with DSC on my car) off.
Old Feb 10, 2004 | 04:03 AM
d-mini-ero's Avatar
d-mini-ero
True enough :smile:
I hardly ever look at the tach....
Learn to drive by the feel of the car and the sound of the engine...
It will come w/ time and it's the only way to drive
Peace,
D
Old Feb 10, 2004 | 09:45 AM
andy@ross-tech.com's Avatar
andy@ross-tech.com
Old Feb 10, 2004 | 10:00 AM
kenchan's Avatar
kenchan
The tricky part of this car at first for me was not so much engaging the clutch
from a 3500rpm or so rev, but how you quickly but progressively let off the gas pedal when you near redline without a nose dive.
When I launch, i don't power shift; I just launch quickly and smoothly and try
to be as easy on the tranny as much as possible (this is a habit from driving
the WRX for a couple of years. )
Old Feb 10, 2004 | 12:29 PM
hondacivic's Avatar
hondacivic
It will mess up my clutch?
_________________
Motoring is a way of life, be true to your life - TeamMINI
<a href="http://www.teammini.net">www.teammin....net</a> Or Play
<a href="http://teammini.proboards26.com/inde...">Name That Part!</a>
Old Feb 10, 2004 | 01:20 PM
andy@ross-tech.com
Think ... what question did you ask? Now, what did I post?
Old Feb 10, 2004 | 01:23 PM
hondacivic's Avatar
hondacivic
thanks
_________________
Old Feb 10, 2004 | 01:30 PM
andy@ross-tech.com
http://www.scu.edu.au/schools/edu/st.../studact5.html
Old Feb 10, 2004 | 01:41 PM
ofioliti's Avatar
ofioliti
Oh, that's mean
OK, so it looks like the best run (fastest at a given time) was run 2 (slightly). Looks like that run was launched at 3500 rpm, progressed to 6000 rpm then shifted to 2nd gear. I think I get that. But what's the significance of "(14.745@93.61)" ???
Old Feb 10, 2004 | 01:43 PM
hondacivic's Avatar
hondacivic
>>Oh, that's mean
yea i know, but did he dump the clutch? wat is sliping the clutch?
thanks OF
Old Feb 10, 2004 | 02:12 PM
andy@ross-tech.com
The best run was slipping the clutch a bit. The numbers like 14.745@93.61 mean the ET and the trap speed in MPH. I've logged a bunch of other runs too, and have found the best results are NOT dumping the clutch. A bit of slip and a bit of wheelspin does the trick.
Old Feb 10, 2004 | 02:13 PM
ofioliti's Avatar
ofioliti
I can't tell from the graphs if the clutch was dumped or released more gently (slipped).
Old Feb 10, 2004 | 02:14 PM
hondacivic's Avatar
hondacivic
Yes i know what 14.745@93.61 means already. Thanks for the help thow. :smile:
Old Feb 10, 2004 | 02:21 PM
ofioliti's Avatar
ofioliti
Makes sense. I suppose you want the maximum torque on the wheels without spinning them. But if you aren't spinning them a little but, you won't know if you are maxing out the torque at the wheels. Clutch dumping just spins the wheels to much. Practice, practice, practice!
Old Feb 10, 2004 | 02:25 PM
hondacivic's Avatar
hondacivic
Yup, yup, yup!
Old Feb 10, 2004 | 02:40 PM
andy@ross-tech.com
Precisely! Wheels actually need to slip some in order to have traction. But, slip too much, and traction goes down.
Old Mar 19, 2004 | 09:56 PM
400ex's Avatar
400ex
Andy,
Looking at your chart, you show the 3 runs, with the et and speed, twice. Didn't you mean to show the et and launch rpm in the second set ?
Old Mar 20, 2004 | 01:16 AM
pocketrocketowner's Avatar
pocketrocketowner
And I still want to know if you mess up your clutch if you dump it....... :smile:
andy.....yuuu da man, man.......nothing like data. THANK YOU!
fastzombie
Sep 7, 2015 12:24 PM
kurosh
Aug 27, 2015 11:54 AM
dave
Off-Topic :: Autos
11
Dec 4, 2003 11:09 AM
sanity29
General Discussion
Aug 1, 2003 08:53 AM
