R55 3rd brake light removal help
Old Sep 9, 2011 | 11:28 AM
txmini100's Avatar
txmini100
I took all 8 screws out and now I'm having a problem releasing the wire assembly that is keeping it from coming out. I didn't want to squeeze and pull to much and break anything.
Old Sep 12, 2011 | 08:13 AM
irontree's Avatar
irontree
There should be a clip that holds the wiring connector to the lamp.
You might be able to use a small flat screw driver to release the clip.
You will also need to disconnect the washer tubing.
The washer hose just needs to be twisted to come off.
Mine looked like it was glued on.
Old Sep 12, 2011 | 08:19 AM
txmini100's Avatar
txmini100
Thanks a million. I'll let ya know how it all goes When I get back to it in a couple of days.
Old Sep 12, 2011 | 09:22 AM
vtrich's Avatar
vtrich
I just replaced the 3rd brake light yesterday. I first removed the light from the body of the car. The light can be snapped out gently using a small flat screw driver. Once it is freed, I took out the 8 screws which keep the housing in place, this allows you to see the connection. The electical fitting comes apart easily when you lift the small snap on top of the fitting. Both the connection from the light and from the car can be slid from the housing. Now you can snap the new light to the housing and install the wire into the little plastic receiver, snap the electical fitting together in the proper place,..and bingo, ready to screw it back together. I think it took me 5 or 10 min. OH, yeah,...and it even works!
Good Luck
Rich
Old Jul 16, 2015 | 02:03 PM
donb43402's Avatar
donb43402
where did you get a replacement and how much did it cost?
Old Jul 17, 2015 | 09:25 PM
grussell's Avatar
grussell
HERE
Old Jul 20, 2015 | 05:54 AM
Thanks for the mention,. There is a red version also. 63257167413
http://www.ecstuning.com/Search/SiteSearch/63257167413/
#ecs
Old Jul 20, 2015 | 11:44 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
63-25-7-167-413 here as well and with free shipping.
888.280.7799 | 6am - 5pm PST
Old Jul 24, 2015 | 12:14 PM
donb43402's Avatar
donb43402
thanks so much
Old Jul 24, 2015 | 12:17 PM
thanks so much
You are welcome.
Dec 23, 2015 10:36 AM
Terry Gallentine
Aug 11, 2015 03:31 PM
quality_sound
Aug 7, 2015 09:36 AM
