Driver's Window Lost Its Viagra
Old Aug 26, 2011 | 07:33 AM
Sealy's Avatar
Sealy
Unhappy Driver's Window Lost Its Viagra
Put my window down at Metro lot exit to swipe my pass, then did the switch for automatic fully up. And got nada. Just like the starch had gone out of it. Auto down works and I can get it up by holding the switch. And auto up and down works on every other window. Tried turning off the key and letting it sit, just wont go. I guess I'll put up with it until I go in for the chrome fix. Eventually.
Old Aug 26, 2011 | 08:49 AM
Miniblue2's Avatar
Miniblue2
Sorry to hear that. BTW, I just got my MAXI shirt in Navy/White. Matches great, thanks.
Bill
Old Aug 26, 2011 | 10:48 AM
Sealy's Avatar
Sealy
Thanks. Pics?
Old Aug 26, 2011 | 11:07 AM
John Richard's Avatar
John Richard
This may be a cousin to your issue, but my driver side window sometimes doesn't go all the way down. Sits up about a half inch. I can somewhat force it down with my thumb. This doesn't happen all the time; just occasionally. Bugs me, too.
Old Aug 26, 2011 | 11:14 AM
GeoffreyM's Avatar
GeoffreyM
There's a thread about this including a reset method. It's worth a try for both issues.
Old Aug 26, 2011 | 12:36 PM
Sealy's Avatar
Sealy
I'm pulling this in from another thread - - -
Originally Posted by schatzy62
For ALL watching this thread.
For the cooper, clubman and verts there are two solutions that work for this.
1. Easy window position reset.
a. Hold window switch in the down position and hold for 10 seconds after the window has stopped
b. Hold window switch in the up position and hold for 10 seconds after the window has stopped
c. Repeat a
Window limit switches should be reset.
for 07+ coopers, 08+ clubman, and 09+ vert if that has not worked then the car needs reprogramming.
Does not sound like my situation, however.
Old Aug 26, 2011 | 02:39 PM
Sealy's Avatar
Sealy
I stand corrected. I had to do it several times. (Maybe had to do with the fact I was motoring and not paying a lot of attention.) It kept resetting to odd up and down combos. Finally got it right.
Old Sep 18, 2011 | 08:36 PM
Lightyr's Avatar
Lightyr
Mine just developed the same problem today. Goes down ok on auto down, but the auto up no longer operates.
Old Oct 5, 2011 | 04:30 PM
user 666209720983's Avatar
user 666209720983
Got the same issue, when I got my Mini back from the dealer (they'd forgot to order the car with the sportbutton, so they had to retrofit it) ..
Luckily the soft reset fixed it (in literally 30 seconds ), now I can swing by the dealer and fix her car as well, as she apparently had the same problem..
thanks for the tip !!
Old Oct 7, 2011 | 04:54 AM
Miniblue2's Avatar
Miniblue2
Look at the window issue post. The anti-trap fix worked great for me. I held the button many times and the window still didn't go all the way down.
Pushed auto up and bopped the window down hard with my hand and it went right on down ALL THE WAY and behaved nice after that. Car is narrow enough so you can bop the other side as well.
Bill
Old Oct 12, 2011 | 10:24 AM
mh17's Avatar
mh17
Driver Side Window Stuck in Up Position
Luckily, with winter coming on, my driver side window is stuck in the up position. Tried the fix suggested for holding the button in the UP position for 10 sec, then in the DOWN position, then in the UP position with no success. Any suggestions? Should I just keep retrying? Thanks. mh17
Old Jan 6, 2012 | 06:38 PM
Frenchis Giuliano's Avatar
Frenchis Giuliano
my driver side is held in the up position as well : have not tried the protocal yet but will tonight: hope it works but if anyone has any other suggestions please let me know:
Old Jan 7, 2012 | 10:04 AM
Sealy's Avatar
Sealy
For mine, they first tried the reprogram trick. That worked for about 20 minutes - long enough to get it off the lot. Finally had to replace the motor assembly. Been fine since.
Old Mar 16, 2012 | 02:08 AM
alohaspeed's Avatar
alohaspeed
took our r60 3x to the dealer they did the reset 2x and the soft ware update today but still not fixed my be they need to change the widow motor?
UncDeo
Nov 4, 2019 04:08 AM
sir5150
Nov 30, 2015 09:54 AM
HogWldFLTR
Sep 8, 2015 05:25 AM
Ntety
Sep 2, 2015 08:39 PM
