R50/53 What clutch to buy
Old Aug 7, 2011 | 08:06 PM
thewizz's Avatar
thewizz
What clutch to buy
Hi everyone,
I tried doing a search for this subject but couldn't find anything.
I have an '02 Cooper (not S) that I need to replace the clutch (not because the clutch is bad but the throwout bearing is making a lot of noise). I drive the car 100mile/day for work and thats about it. Nothing fancy! The car had 160,000 miles right now on I think the original clutch. I am the 2nd owner so not 100% sure. I bought the car with about 40K on it, so I didn't figure the clutch had been replaced yet.
So my question is, should I put a stock clutch back in it or should I put something else in it. $$$ is always a concern. Any suggestions?
Thanks for any input!
Old Aug 7, 2011 | 08:18 PM
JumpingJackFlash's Avatar
JumpingJackFlash
If you have done no engine mods, OEM is just fine. I happened to find this ad for
someone selling theirs for $160: http://npora.ipbhost.com/index.php?showtopic=30758. That deal appears to include a new flywheel, which is a steal. If that one is no longer available, you can get a kit here for $175: http://www.clutchcityonline.com/products/03-061.shtml.
Don't forget the clutch alignment tool. Also consider replacing the slave cylinder; make sure to do a thorough bleeding if you change it yourself.
Old Aug 7, 2011 | 08:26 PM
Minian's Avatar
Minian
Check into "Valeo," Way Motor Works has them.
Old Aug 7, 2011 | 08:27 PM
dannyhavok's Avatar
dannyhavok
Consensus seems to be OEM is best for most applications, especially if you're not running a heavily modified S putting down big power. Plus, the first one lasted 160,000mi.. wow!
Old Aug 7, 2011 | 09:46 PM
GordonP66's Avatar
GordonP66
+1 on the OEM. (OEM grade Valeo, Sachs & LuK) The uprated performance pressure plates usually have significantly higher clamping pressures which can shock load the already sketchy stock R65 transmission.
There is a Kevlar disc available for the R50 which will outlast most of the organic discs. The catch 22 is that Kevlar has a lower coefficient of friction than most organic compounds so you have to use a heavy duty pressure plate with it to avoid clutch slip.
If you are going to do the clutch work yourself, it might be worth replacing the front input shaft bearing in the transmission. The stock bearing, P/N 23211036989 made by SNR, is a leading cause of R65 transmission failures. SKF makes a high quality bearing that fits for under $30. You need a gear puller to remove 5th gear off the end of the input shaft so you can remove the input shaft from the transmission. Next the bearing has to be pressed off the input shaft. If you don't have access to a press, most transmission shops will remove the bearings & press the new ones on for $45 - $65. Also, make sure you use the factory specified high temp grease where the T/out bearing rides on the trans shaft. BMW part# 83239416138. Throw in some new trans seals, keep the oil changed & you might see another 160,000 miles.
Old Aug 9, 2011 | 06:43 PM
thewizz's Avatar
thewizz
Thanks for all the suggestions! Sounds like stock will be fine. Thanks again.
Old Aug 29, 2011 | 11:48 AM
yetti96's Avatar
yetti96
What was the outcome of this? I have a very noisy tranny right now and I suspect the throwout bearing is to blame but I only have 50k miles on my R50 :(
Old Aug 29, 2011 | 12:53 PM
Blackbomber's Avatar
Blackbomber
Yetti, is the noise apparent with the clutch depressed, or released? If depressed, suspect throwout bearing. If it's noisy underway, then it sounds like your Midlands transmission is getting ready to take a dump.
Old Aug 29, 2011 | 02:59 PM
yetti96's Avatar
yetti96
While the clutch is not depressed, foot resting off to the side. It grinds like there is no fluid inside of it. Horrible noises and funny face from the service techs and the SM as I dropped it off this afternoon. I am in a loaner now as we speak. Fingers crossed it is the internals as the extended warranty will cover it and the clutch is all on me.
Old Aug 29, 2011 | 03:19 PM
thewizz's Avatar
thewizz
Sadly mine was not the throw out bearing but the tranny. A few days after posting a bearing on my output shaft let go throwing pieces of bearing through the tranny and locking the tranny up. Thank God I was only going about 20mph at the time! I am now looking for a replacement because too much damage to repair. Housing broke!!! I was stupid for not looking at it sooner!
Old Aug 30, 2011 | 06:27 AM
rlich8's Avatar
rlich8
Don't want to hijack this thread but question: do these clutches use a carbon throwout bearing?
Old Aug 30, 2011 | 06:47 AM
Blackbomber
Yetti - I GUESS this is good news, then. Your Midlands is definately toast. It's pretty common, unfortunately, even at low mileage such as yours. You may want to buck up for a clutch kit while they are in there. If they don't resurface the flywheel, I don't see it being more than 1/2 labor (and that's generous) to do the friction disk / pressure plate / throwout bearing. The parts will run about $300, I think. Bad news is that I'm not sure if there are any brand new Midlands transmissions available any more. Six months ago, Way told me he had one (or more), but I had already purchased my Getrag. If you drove it there, it should be rebuildable. A junkyard Midlands is a crapshoot, because of the high failure rate, which is why I went with the Getrag 6 speed.
Wizz - From what I hear, 160k on a Midlands is a pretty good lifespan. I'm hoping your Midlands is rebuildable. Are you doing the work yourself?
Old Sep 1, 2011 | 05:55 PM
thewizz's Avatar
thewizz
Yep, I will do everything myself! I don't like to have other people touch my vehicles if I can help it. I have not had the heart to completely tear down the tranny yet. I know the output shaft is toast! So far just what I have added up that I know I need will run around $1200 parts. I was hoping to find a used one with low miles for around the same price, but not a chance. I found some low mile tranny's but they are around $2500. I found several later ('05ish) 6 spds but from what I have read it will cost me a lot more to put one of those in than to try and rebuild mine. Will let everyone know what I end up doing!
Old Sep 1, 2011 | 06:53 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We can get you a new trans for less than those used ones. email us and we'll get you a quote with shipping. And yes for a Cooper stock clutch is best.
info@waymotorworks.com
Old Sep 1, 2011 | 07:01 PM
yetti96's Avatar
yetti96
I think I am going with a Valeo since it is what the dealership was going to put on it. My normal mechanic told me his cost on the part is around $170 and that is the route I am going . I will drop it off at the dealership and they will put it on once the unit comes in.
eliseo1981
Jan 28, 2021 02:45 PM
Sep 17, 2015 09:27 AM
L3Mix
Aug 26, 2015 07:00 PM
Camaro108
Aug 25, 2015 02:44 PM
DiGiPiMP
Aug 24, 2015 11:04 AM
