Drivetrain My solution to the PVC system dilemma.
Old Aug 1, 2011 | 05:10 PM
MNIPWR's Avatar
MNIPWR
So after reading through all the posts about catch cans and our PVC system I decided this is the easiest thing to do.
First I contacted our good pal from the other side of the pond CZAR and purchased to of the caps from him. I received them in the mail today and got right on installing them.
First I removed to hose from the crankcase to the manifold and put in the two caps.
Then I went to the local auto parts store and picked up a neoprene plug and a breather filter (to substitute till I can get an appropriate length hose to run under the car)
This is the end result.
Any questions, comments or concerns? I would like to know before my car blows up.
Old Aug 1, 2011 | 09:43 PM
tintman718's Avatar
tintman718
Well, that breather filter is going to drip oil and make a mess. I don't see how you could avoid using a catch can? Also, I don't know how the sensor you removed from the inlet tube is going to react.
Old Aug 1, 2011 | 09:55 PM
MNIPWR's Avatar
MNIPWR
The filter is just temporary I'm waiting for an adapter and hose in the mail. That is also not a sensor in the intake. It is a heating element, so I don't think there will be any issues with that. What do you mean about the catch can?
Old Aug 2, 2011 | 11:47 AM
bluefox280's Avatar
bluefox280
I was wondering what that was during my catch can installation. Thanks.
An oil vapor condensing catch can for those who don't or can block off the valve cover:
https://www.northamericanmotoring.co...t-install.html
- Erik
Old Aug 2, 2011 | 05:55 PM
MNIPWR's Avatar
MNIPWR
- Erik
I know what a catch can is. I am wondering when he meant by " how you avoided using a catch can)
Old Aug 2, 2011 | 06:12 PM
wellzy's Avatar
wellzy
I am looking at running it into my down pipe just need the time to get it sorted.
Old Aug 2, 2011 | 08:30 PM
MNIPWR's Avatar
MNIPWR
I would be careful with that. I think the down pipe has a lot more pressure in it than the crank cake puts out. You might end up pushing exhaust gasses into the hose. Also the down pipe its very hot and might melt whatever hose you use. I would suggest running is into the exhaust stream farther back.
Old Aug 3, 2011 | 08:21 AM
wellzy's Avatar
wellzy
Looking at a kit from summit with a check valve, as well as putting a pipe off then a hose.
Thanks for pointing out problems I might have.
Old Aug 3, 2011 | 08:21 PM
killerfox's Avatar
killerfox
I also got the plugs from CZAR and eliminated the hose all together. I added a BSH catch can on the driver's side hose. I have been running like this for over 2 months without a single issue.
Old Aug 3, 2011 | 09:57 PM
MNIPWR's Avatar
MNIPWR
Thats good I'm amazed at the amount of oil that comes out. I can smell it every time it does, smells awesome! I love it.
Old Aug 7, 2011 | 02:32 AM
david in germany's Avatar
david in germany
Oil dumped into a hot exhaust? I think you need to rethink this. Run a catch can. Tou don't really need to recirculate it back to the intake track but catch it, your little filter will be an oily dripping mess soon enough.
Old Aug 11, 2011 | 02:17 PM
Freddie's Avatar
Freddie
What did you used to seal the hole on the intake?
Thanks.
Old Aug 11, 2011 | 02:21 PM
bluefox280's Avatar
bluefox280
Thanks.
Same plug fits the valve cover and the intake manifold.
* https://www.northamericanmotoring.co...se-delete.html
- Erik
Old Aug 11, 2011 | 02:32 PM
MNIPWR's Avatar
MNIPWR
Its a expandable plug, or neoprene plug. Some thing deferent name. Its not in the pic but i put the heater and plugged it back in then plugged it. just incase the plug fails it won't get sucked into my turbo.
Old Aug 19, 2011 | 11:16 AM
///Mflossin's Avatar
///Mflossin
It's a .99 expandable freeze plug.
Old Aug 19, 2011 | 03:21 PM
SooperCuperErik's Avatar
SooperCuperErik
OT, I like your furthest back corner spot by the engineering building these last few days.
Old Aug 19, 2011 | 03:46 PM
///Mflossin
Ha...ha. You caught me. I haven't had a chance to wash the car as I've been on vacation. Just hit 8,888 miles tonight on the way home.
Filmy
Sep 7, 2015 08:27 PM
jesterofatlas
Sep 4, 2015 11:23 PM
mimaal
Sep 4, 2015 09:09 AM
M7Speed
R58 :: Coupé Talk (2012+)
Sep 3, 2015 07:29 AM
M7Speed
Sep 3, 2015 07:27 AM
