R50/53 5-Speed lube to ease shifting?
Old Jul 30, 2011 | 12:54 PM
White_Knuckles's Avatar
White_Knuckles
Did a quick search and am not catching what I need to find out. With a 2004, my wife fiddles with the shifter getting it into reverse. I pull it down from first into second and then select reverse without any problem. Going from first to reverse seems that the syncros mess with you.
Some may have found a magic lube such as Redline gear oil that cures or makes shift selection better? Whats the voodoo here? Gotta help the wife out - her shifting technique makes me crazy.
Old Jul 30, 2011 | 01:00 PM
mrbeebe's Avatar
mrbeebe
I have an 05 and ultimately had to replace the shifter cables.
Old Jul 30, 2011 | 03:56 PM
rkw's Avatar
rkw
That's because the reverse gear doesn't have synchro in the R50/R53. It does in the R56.
Old Jul 30, 2011 | 04:55 PM
CV Joint's Avatar
CV Joint
I don't know about the R50, but you are mistaken about R53. There is a syncro on Reverse gear on that car.
Old Jul 30, 2011 | 07:47 PM
hexon's Avatar
hexon
sometimes you just need to double clutch. Its a quirk.
Old Jul 30, 2011 | 08:56 PM
rkw's Avatar
rkw
No synchro for reverse gear in the 5-speed manual.
Old Jul 30, 2011 | 08:57 PM
dannyhavok's Avatar
dannyhavok
That explains why getting into reverse is so hit or miss. I'll try shifting into 2nd first.
I had my trans fluid changed at ~35000km to fix tough shift into 1st. It helped
Old Jul 30, 2011 | 09:44 PM
White_Knuckles
Thanks guys at least it's not just a "girl" thing. My wife will nail me for that one.
IQRaceworks
53
Jun 28, 2024 07:29 AM
OutMotoring
Mar 3, 2017 06:29 AM
02miniSguy
Nov 17, 2015 10:29 PM
bahman
Sep 30, 2015 01:59 PM
gnhovis
Sep 28, 2015 04:07 AM
