R55 CF Dash Trim
Old Jul 16, 2011 | 11:05 AM
lakersguy's Avatar
lakersguy
CF Dash Trim
Are there any posts/links that show/tell how to remove the dash trim pieces? I want to wrap mine in carbon fiber, but I am not sure how to remove the original parts.
Thanks in advance for your help on this search!
MOTOR ON!
Old Jul 16, 2011 | 01:18 PM
slimjimtell's Avatar
slimjimtell
Drivers side
Move steering wheel in DOWN position.
Remove 2 torx screws that hold the tach to the steering column
Slide tach forward and move out of the way
Get your fingers behind your dash piece and pull...it's tight but it WILL come off. I tend to pull right behind the tach to the left first. There are 3 pins holding it in
Passenger side
Open secret compartment
Remove 2 torx screws on under side of door
There are 3 thin clips holding the door on.
The clips are on the bottom side of the door
You may need a flashlight to see them
Use a very thin screw driver to release each pin
Remove, put new one on, put screws back in.
Old Jul 16, 2011 | 01:22 PM
slimjimtell
FYI,
to wrap them properly, you will need to remove the face from the mounting piece. You have to drill out the plasic mounting points on the back side of each piece. The face is held to the back by melted plastic. Then you can skin the piece and remount by using hot glue or another form of adhesive. Hot glue works best using the original mounting points.
Old Jul 16, 2011 | 01:41 PM
lakersguy's Avatar
lakersguy
THANKS so much for the useful information.
Old Jul 17, 2011 | 05:44 AM
Whistler NC's Avatar
Whistler NC
Lakersguy,
Slim Jim got me started on this project and my car turned out really slick. I learned a lot so that my wifes door pulls turned out even better.
You can follow my progress here:
https://www.northamericanmotoring.co...oor-pulls.html
I DID NOT remove the secret door cover from the back piece as jim described by melting the rivets. I really didnt know I needed too...LOL.
I wrapped the skin around it, trimmed the edges and used a sanding block to square up all the 4 edges when done. It looks great and in the closed position, it looks OEM.
Two things I did differently on her door pulls:
1. Use light heat from model airplane covering heat gun on each coat of epoxy to remove bubbles.
2. Do not lacquer the parts when done. I had the right humidity and temps and still got an eggshell finish on mine. After 6 coats of epoxy I took her door pulls to a 6" buffing wheel and used carnuba wax and they look like glass.
Good Luck!
I'm about to try a spare set of mirror caps I bought, but I'm dreading the sanding...
Old Jul 17, 2011 | 07:07 PM
slimjimtell
By removing the face from the base plate, you can get a really crisp edge.
Old Aug 2, 2011 | 07:42 PM
e46jb's Avatar
e46jb
Any pics of the torx screws on the tach?
Is there added steps for the openometer?
Old Dec 8, 2011 | 07:07 PM
lakersguy's Avatar
lakersguy
CF Dash trim
Here are a couple of pics of my completed dash....thanks to those that "showed me the way" on the forum!!!
Old Dec 9, 2011 | 06:25 AM
mdsbrain's Avatar
mdsbrain
Looking good there and thank you guys for the tips on the car dis-assembly
Alpha Motoring
Sep 7, 2020 07:34 PM
OutMotoring
Mar 3, 2017 06:29 AM
Oct 1, 2015 12:28 PM
Oct 1, 2015 12:13 PM
