crank position sensor o-ring gasket - how to?
Old Jun 24, 2011 | 12:00 PM
JAB 67's Avatar
JAB 67
I will be putting my car in 'service mode' soon so as to replace my cooling fan. I suspect that my crank position sensor is leaking. What is involved in replacing that gasket? Access from above, or below? If it requires removal of the supercharger, I'll save it for another day; the leak isn't that bad. TIA.
Old Jun 24, 2011 | 12:08 PM
MCS Fever's Avatar
MCS Fever
https://www.northamericanmotoring.co...ft-sensor.html
Old Jun 24, 2011 | 12:20 PM
JAB 67's Avatar
JAB 67
Wrong one. That's the camshaft position sensor; I'm talking about the crankshaft position sensor.
Old Jun 24, 2011 | 01:04 PM
MCS Fever's Avatar
MCS Fever
https://www.northamericanmotoring.co...placement.html
healey67's Avatar
healey67
When you have the fan out, you can see the sensor. Its held on by 1 bolt. Pretty self explanitory. Pull it out and replaced the oring on it... Then put it back in.
Svejk
Feb 24, 2019 12:18 PM
5904
Aug 27, 2015 10:00 PM
SheldonCooperS
Aug 25, 2015 11:57 AM
Aug 19, 2015 12:51 PM
pocketmaster
Aug 11, 2015 07:36 AM
