R50/53 2006 JCW Camshaft Position Sensor
Old Jun 24, 2011 | 11:19 AM
edinamini's Avatar
edinamini
Hey All,
So my car threw a check engine light today. The code is for a Camshaft Position Sensor. It looks like the part is around 120$. I am not sure how to find where this part is in the engine. I did some searching around on the forums and did not find a DIY guide. Has anyone changed this part in their car. Can I still drive the car with this sensor having issues? Any guidance that you all can offer would be great.
Old Jun 24, 2011 | 01:02 PM
healey67's Avatar
healey67
The camshaft sensor is at the front of the engine, in the end of the cylinder head. If you're looking at the engine its on the far left next to the bracket the goes over the engine mount. Its not that hard to change out really. Put a Jack stand under the engine, remove the support bracket at the front of the engine and replace the sensor.
Old Jul 9, 2011 | 06:46 PM
edinamini's Avatar
edinamini
Sensor replaced and still having the same code.. The code reads Camshaft Position Sensor Circuit. So I assume that I could be an issue in the Sensor, Wiring, or PCM/ECU Any thoughts on where to start and how to troubleshoot this further?
Old Jul 9, 2011 | 10:42 PM
Phucket's Avatar
Phucket
Did you clear the codes? The only time I have gotten this code is when my timing was off. Once I had the timing issue fixed the code remained till cleared.
Old Jul 9, 2011 | 10:45 PM
Revolution Mini Works's Avatar
it's your CRANK position SENSOR....... the system gives the wrong code
Old Jul 9, 2011 | 10:57 PM
Phucket's Avatar
Phucket
Forgive my ignorance, but they are not the same thing?
Old Jul 9, 2011 | 11:00 PM
no,
Crank sensor is on the front of the block which monitors the crank position
the cam position sensor is on the cylinder head and monitors the cam position.
the problem with the coding system through the obdII it will tell you the cam sensor is bad when it's actually the crank position sensor
Old Jul 9, 2011 | 11:09 PM
Phucket's Avatar
Phucket
Well that is good to know. Something I will have to keep in mind since my Mini seems to have anything possible break on it.
Old Jul 10, 2011 | 09:06 AM
edinamini's Avatar
edinamini
But how do you know that this is the case?
Old Jul 10, 2011 | 09:22 AM
experience.....
where are you located?
Old Jul 10, 2011 | 02:27 PM
edinamini's Avatar
edinamini
Ohio
Old Jul 14, 2011 | 08:27 PM
minimic's Avatar
minimic
my SES and DSC light have been coming on for about 3 days. my engine code was P0340 (camshaft position sensor circuit) so i guess its my crankshaft position sensor. i'm glad i found this thread. have you fixed yours yet and if so, any results???
thanks for posting!
Old Jan 29, 2012 | 12:24 AM
johnf36's Avatar
johnf36
any results guys?
Old Sep 28, 2012 | 05:13 PM
Cole9953's Avatar
Cole9953
Just got a p0340...
Updates please
Old Sep 8, 2015 | 03:47 PM
Steffen.Johnson's Avatar
Steffen.Johnson
Originally Posted by Cole9953
Just got a p0340...
Updates please
Same happened to me today any help or updates anyone?
Old Aug 19, 2025 | 04:20 PM
Headache's Avatar
Headache
Short story first, was chasing the cause of a slight misfire/ jump in 3rd while accelerating hard, no warning lights. Found a cracked CAM sensor, replaced and still didn't fix it.. Around a month after changing the CAM an engine warning light P0341 came on, checked voltages (OK), wires (OK) for CAM sensor even wiggled them to check for breaks. Left me with timing, changed the chain, CAM sprocket, tensioner and timed it up, wiped the codes, cycled ignition, all ok. On reflection, the chain was less than 0.5mm stretched, and I didn't check if the timing was off before removing the old chain, should have only changed the tensioner first to see if that was the cause.
W0TM8
Dec 19, 2019 07:50 AM
Svejk
Feb 24, 2019 12:18 PM
blackie
Aug 23, 2015 08:44 PM
pocketmaster
Aug 11, 2015 07:36 AM
