Idling problems
Idling problems
2007 Cooper, 50k
The car has been running faultless until tonight on the way home from work.
I got to a set of lights and when stopped the revs were up and down then finally settled?
I thought it was a 1 off until i got to another stop and the revs died so i had to re start
At another give way it did the same again (now getting peed off) and when i got home the revs were up and down again
It drives and revs ok when on the move so what could it be?
he clutch is at the top and i'm not sure if that connected as you have to dip it when starting? it isn't slipping so can't be that bad
any ideas?
any ideas?
I have always used a hand propane torvh (not lit) and swept it around all the vacuum hoses to find the leak.
Alot of people frown on that one, but it's not as dangerous as some say and work pretty well. You can use ether starter fluid too.
2007 Cooper, 50k
any ideas?
any ideas?
We have another thread here on idling issues. One owner found success after replacing all the o-rings between the intake manifold and the throttle body and the throttle body of the head. I'm still chasing mine.......
Marco Guardado
Sep 15, 2015 01:22 AM
Sep 1, 2015 03:36 PM
Drivetrain Won't hold idle after work performed
Lt. Dan
Aug 10, 2015 08:23 AM
