Navigation & Audio HK amp connector?
Old May 14, 2011 | 04:52 PM
Partsguy198's Avatar
Partsguy198
HK amp connector?
Does anyone have any type of breakdown on the colors of the wires going into the HK amp? Any diagram or schematic?
Old May 15, 2011 | 09:21 AM
GBMINI's Avatar
GBMINI
This is the first gen connections, maybe the colors will clue you ...
http://www.gbmini.net/downloads/HKconnections.pdf
Old May 16, 2011 | 08:58 AM
strobeyprobey's Avatar
strobeyprobey
http://www.bmw-planet.com/diagrams/r.../r56/index.htm
Use Internet Explorer. Go get the Adobe SVG plugin for XP. Then navigate to Complete Vehicle, body, Audio Video..., Sound Output, HIFI system.
This is for the HIFI, but the HK uses the same connector. Also keep in mind the colors could be different as this is for for 07 cars. But it should be a good starting point.
Old May 16, 2011 | 10:39 AM
Kevin@Integral Audio's Avatar
All the pin-outs on the h/k are the same as the HiFi. IIRC, the only color changes are on the Right Rear channels. This is for pre-2011 LCI. Pin-outs continue to be the same post-LCI, but there may be additional color changes in the harness.
HiFi Amplifier Connector (X10266) - R56 HiFi & H/K
Rear Right ++
Brown w/ Orange Stripe (‘07-’09)
Grey w/ Violet Stripe (2010+)
Pin 8
Rear Right --
Yellow w/ Red Stripe (‘07-’09)
Grey w/ Yellow Stripe (2010+)
Pin 16
Old May 17, 2011 | 11:19 AM
Partsguy198
Thanks !!
PsychoRallye
21
Feb 17, 2019 06:08 AM
martinb
Oct 7, 2015 05:00 PM
schr5530
Oct 5, 2015 08:28 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
