Navigation & Audio Procedure to update NAV disk
Hi - I got a new nav disk, popped it in and am told to shut system down for five minutes and restart after 5.
Now the funny thing is that the nav interface (hard button or otherwise) has no shutdown function. I killed the ignition, but I don't hear the disk whirring.
So what is the official procedure to update the nav disk?
Weird.
Thanks in advance!
Weird.
Thanks in advance!
Worked just as advertised above. Load it, shut the car off - go to work. Came back, et voila.
Now I need to figure out how to display the red light cameras embedded in the data. The main reason I got this disk after all. I don't suppose anyone here wants to chime in? If I can just get to the list of what POI is shown on the screen as icons, then I should be able to select it. It's the same database used by the BMW system and there it's selectable.
As you probably saw in the other thread - you must have gotten the wrong set - you need Professional, not High. Best of luck.
P
P
Went back, & picked up the proper disk, it updated in 5min, as soon as the disk went it, it recognized it, & told us to shut off the car for 5min.
Got the 2011 Nav DVD. I noticed it now has more items on the map such as additional lakes and trails I believe. Too bad I still cannot do a general search of POIs as the 2011 MINI Connected with nav allows you to.
http://store.minigpsmaps.com/prod_01...pc=65902199845
and for 1st-gen MINIs, 65902199846
http://store.minigpsmaps.com/prod_01...pc=65902199846
Anyone out there know if the BMW nav update will work on the MINI?
In other words, might the difference between 65902199843 (BMW) and 65902199845 (MINI) just be the packaging?
I ask because this place is much cheaper than the "official" source above.
http://www.bmwnavdvd.com/5-2011-bmw-...-professional-
(hell, I may throw $30 at them just to test it myself)
Navigation & Audio BT/DVD/NAV Upgrade for 2013 Convertable
qwispichkn
Sep 17, 2015 11:28 AM
