What is this indicator light means?
Old May 4, 2011 | 08:54 AM
PetGost's Avatar
PetGost
Need help folks ...my guess is a brake indicator of some sort.
Thanks.
.a
Old May 4, 2011 | 09:06 AM
Capt_bj's Avatar
Capt_bj
brakes have worn enuf to trip one of the sensors... need a visual check to determine if it is front or rear
you need to replace those pads and the consumed sensor. generally the rotors would be changed too but you many be able to go w/out
Old May 4, 2011 | 09:24 AM
PetGost's Avatar
PetGost
First of all, thank you. That's what I thought. Another question, while I have your attention. Could I fit the R56 JCW big brakes to an R53 for the front and rear?
Thanks.
.a
Old May 4, 2011 | 09:28 AM
Vollgas's Avatar
Vollgas
The front brakes will swap out ok.
I believe the R56 rears are different than R53's as far as mounting points go.
Old May 4, 2011 | 01:13 PM
PetGost's Avatar
PetGost
I've done a quick search here and I'm beginning to learn that would be the case.
Thanks.
.a
Wohnson89
Jun 10, 2020 04:53 AM
emulajavi
Dec 24, 2018 09:15 AM
missinmyjeep
Aug 22, 2015 07:13 PM
Herleman
Aug 16, 2015 06:41 PM
