R50/53 Differences between 2003 & 2004 alarm
Old Jan 19, 2004 | 12:08 PM
dcsmd007's Avatar
dcsmd007
Coordinator :: PDX MINI
I've just ordered an alarm for my 2004 MCS. I know there're some changes between 2003 and 2004. I'll be installing it myself. Has anyone added an alarm to a 2004? In term of installation, what's the difference between the 2004 and the instructions (from 2003)? Where can I get instructions for 2004 alarm?
:smile:
_________________
04 IB/W JCW MCS
Old Jan 19, 2004 | 12:30 PM
Pebbles's Avatar
Pebbles
Here's the best I could find :
To Quote Gabe Bridger where he lists 2004 accessory additions :
"Alarm system $295 (I believe this is much more plug and play than the previous system and very similar to the current 3 series system)"
Go here for more :
2004 alarm kits available - with prices and comments
MINI Instructions for OEM systems
_________________
MR BRIDGER
<td align=center><b>MR<p>BRIDGER</b>
</td>
Old Jan 19, 2004 | 01:33 PM
dcsmd007's Avatar
dcsmd007
Thank you for the info, Pebble! :smile:
Classic sells the alarm for $236. I'll attempt to install it with the 2003 instructions. 2004 supposed to be easier than the 2003. I hope by using 2003 instructions will not confuse me.
Old Jan 19, 2004 | 07:53 PM
jmciver's Avatar
jmciver
The 2004 kit has one less component than the 2003 kit. There is no separate tilt sensor in the 2004 kit, otherwise all of the other components are the same as the 2003 kit. You will also have to get the alarm programmed by the dealer once you install it.
Old Jan 19, 2004 | 07:54 PM
MeanGRN's Avatar
MeanGRN
Davecsumini, I havn't installed my alarm system yet (I pick up my MCS on Friday), but the main change is the the tilt sensor that was mounted in the rear boot area on the earlier MINI's is now encorporated into the siren that is mounted under the bonnet. That is the only change that I can see. Looks straight forward to me. MINIusa has the install time at .75 hours. Hope this helps.
Cheers,
JD
Old Jan 19, 2004 | 08:43 PM
Kiwi's Avatar
Kiwi
Does anyone know if the '04 alarm kits are made by MINI, or is it made by an after-market alarm company? And if so, who.
Old Jan 20, 2004 | 06:31 AM
MeanGRN's Avatar
MeanGRN
Kiwi, as far as I know it is made by MINI. One part is a replacement wiper stalk with a red led on the end that flashes when the system is acivated.
Cheers,
JD
_________________
I majored in Eastern Philosophy and Western Movies, kinda like the Yin and Yang and the Bang Bang! (Almost home) Mean Green, '04 BRG/W MCS, 3 pkgs w/three spoke wheel, Auto wipers, H/K, Cordoba Leather, Ociari Body Kit, White S-lites, Rear Fogs, Pin Strip
Old Jan 20, 2004 | 02:05 PM
dcsmd007's Avatar
dcsmd007
I thought about getting the aftermarket alarm. However, I want to utilize the factory remote. So I ended up getting the factory alarm. IMO, $236 is reasonable, considering it's a MINI factory item. :smile:
Old Jan 20, 2004 | 02:26 PM
MeanGRN's Avatar
MeanGRN
The key remote was my reason to go with the factory alarm also. Paid the same price from Classic. Don't forget that your dealer may charge you to reprogram your alarm.
Cheers,
JD
Old Jan 20, 2004 | 06:31 PM
dcsmd007's Avatar
dcsmd007
Thanks for the reminder! :smile:
I'll have both the alarm and the fog light switches activated the same time. I believe the dealer quoted me $45 for programming it. Not too bad!
sevin
May 2, 2026 06:11 AM
Spank
11
Apr 9, 2020 02:23 PM
doug5g
12
Apr 17, 2019 12:44 PM
PrimePower
Aug 11, 2015 12:51 PM
