R56 Service indicator question
Old Apr 19, 2011 | 08:23 AM
90210oxygenblue's Avatar
90210oxygenblue
My car was serviced in December at 9100 miles. Currently the car has 13500 and service indicator shows next service at 15,000 miles.
Car is in to dealer for unrelated, and I asked them if they would service it to save me the trouble of bringing it back again next month.
My service advisor said, that service indicator showing "15000" means the car will need service after 15000 more miles, not at 15,000 miles.
My owners manual is in the car, so I can't look.
Is that correct? Am I misreading the service indicator?
Old Apr 19, 2011 | 08:33 AM
MCS Fever's Avatar
MCS Fever
Yes, per the CBS count down or 1 year whichever comes first.
Old Apr 19, 2011 | 08:34 AM
Bigprfed22's Avatar
Bigprfed22
service indicator is a "count down" type notification. Dependant on mileage and how you run your engine believe it or not.
Old Apr 19, 2011 | 08:35 AM
90210oxygenblue
Thanks. So what the service advisor is saying, is correct, 15000 MORE miles?
Old Apr 19, 2011 | 08:36 AM
Bigprfed22's Avatar
Bigprfed22
yup. change it every 5 at minimum, just my personal thing.
Old Apr 19, 2011 | 08:40 AM
90210oxygenblue
Ok got it, no problem, I will do a home oil change. Thanks for quick reply.
They did give me a 2011 Loaner
Old Apr 19, 2011 | 08:41 AM
MCS Fever's Avatar
MCS Fever
What part of YES don't you understand?
It's a countdown indicator. Just be sure and check your oil level, ours is most def using 1/2qrt per 5,000 miles so far. We changed it at 6 months and 5,000 miles ourselves, stealership gets the 12 month change. Our MINI sees many short grocery getter trips and about 10,000 miles a year. So will probably stay on the 6 month interval. Although many on here do go the recommended intervals just fine and dandy.
Old Apr 19, 2011 | 08:44 AM
90210oxygenblue
It's a countdown indicator. Just be sure and check you oil level, ours is most def using 1/2qrt per 5,000 miles so far. We changed it at 6 months and 5,000 miles ourselves, stealership gets the 12 month change. Our MINI sees many short grocery getter trips and about 10,000 miles a year. So will probably stay on the 6 month interval. Although many on here do go the recommended intervals just fine and dandy.
Sorry slow this morning, as had to wake up at 530am for service appt Yes ours is used like yours, so I will change it at 15,000
It is showing front brakes, "23000" and rear brakes "27000" so I guess given it is a countdown indicator I will be right out of warranty, when that is needed
Old Apr 19, 2011 | 11:01 AM
Blainestang's Avatar
Blainestang
Just use your brakes more and squeeze them into the 'free' maintenance period. :D
Old Apr 19, 2011 | 11:37 AM
MCS Fever's Avatar
MCS Fever
Here's one of those fine and dandy cars using the CBS oil change intervals:
https://www.northamericanmotoring.co...-analysis.html
W0TM8
Dec 19, 2019 07:50 AM
emulajavi
Dec 24, 2018 09:15 AM
missinmyjeep
Aug 22, 2015 07:13 PM
Aug 19, 2015 12:51 PM
oldkid6
Aug 11, 2015 08:13 PM
