Suspension Worn Brake Pad Warning Light Question.
Old Mar 27, 2011 | 10:21 AM
Dwight Walhood's Avatar
Dwight Walhood
When you replace brake pads and sensor on an R56, does the service indicator have to be re-set, too? Reason I ask is that I just changed rear pads and sensor and 150mi. down the road that warning light came on. Checked all connections and they're solid. Read somewhere that the car's computer has to be told it's dealing with a new sensor. True?
Old Mar 27, 2011 | 11:01 AM
iwashmycar's Avatar
iwashmycar
Front sensor??
Old Mar 27, 2011 | 12:29 PM
Dwight Walhood
No, just the rear one. Front's fine.
Old Mar 27, 2011 | 12:31 PM
iwashmycar's Avatar
iwashmycar
Considering that it is just a simple circuit break sensor, I wouldnt think the computer would "care" once you put a new sensor on.
Maybe take it to a parts store and see if there is a code??
Old Mar 27, 2011 | 01:13 PM
jcauseyfd's Avatar
jcauseyfd
Yes, you have to perform a reset after you replace the sensor.
Old Mar 27, 2011 | 01:20 PM
Dwight Walhood
Thanks mucho ! Can I do the reset myself or do I need to go to the dealer? No biggy on going to the dealer as we finally got a real good one (Penske) in these parts.
Old Mar 27, 2011 | 01:27 PM
jcauseyfd's Avatar
jcauseyfd
You can do it yourself. Do a search on how to reset the interval for the oil change for an R56. The brake reset is accessed the same way.
Old Mar 27, 2011 | 02:31 PM
iwashmycar's Avatar
iwashmycar
See this one:
https://www.northamericanmotoring.co...procedure.html
Old Mar 27, 2011 | 04:06 PM
Dwight Walhood
Originally Posted by iwashmycar
HOT DAMN, IT WORKED! Took 3-4 tries, but that stupid light finally went out for good. Thank you soooooooo much!
Old Apr 8, 2011 | 09:34 AM
countryboyshane's Avatar
countryboyshane
The service menu is soooooooooo logical right?! I'd scrap the sensors so you don't ever have to worry about them ever again. Twist the wires together at the and of the sensor and be done with them forever.
bjcarter2
Aug 31, 2015 04:03 PM
JamJam43087
Aug 16, 2015 02:02 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
