Is this normal
Old Mar 19, 2011 | 06:45 PM
Stryker305's Avatar
Stryker305
Is this normal
Have a 09 r56 seems my clutch when I depress it to shift gears on it's way down it runs into a black tubular part right above the dead pedal the part has a metal tube on the bottom of it , what the he'll is that and is everyones clutch doing that or did the prior owner push too much to the left with his foot????
Old Mar 19, 2011 | 08:07 PM
Stryker305's Avatar
Stryker305
50 of you read this and said nothing...... Must be normal
Old Mar 20, 2011 | 05:28 AM
timfitz63's Avatar
timfitz63
Patience, grasshopper. Sometimes even the Jedi Council does not consult the Force within 14 hours...
For what it's worth: no, I've not really encountered what you're describing with my clutch pedal. Sometimes my foot will catch on something (may even be whatever it is you're describing), but never the pedal itself; and I just attribute those occurrences to my foot placement being a bit off on the clutch pedal.
Old Mar 20, 2011 | 09:36 AM
Stryker305's Avatar
Stryker305
Thanks master hey but just for craps and giggles check on your clutch on the floor board and see if you have a black tubular part with a metal hose or tube just above your dead pedal which when the pedal is depressed could come in contact with it. Thx again
Old Mar 20, 2011 | 09:48 AM
timfitz63's Avatar
timfitz63
I'll check. But at the moment, I'm away from Coruscant () on business, so I won't be able to check until the end of the week.
Perhaps someone else on the forum is able to check theirs sooner...?
Old Mar 20, 2011 | 10:23 AM
Doug W's Avatar
Doug W
You're speaking about the clutch input cylinder.
I have an '09 JCW Coupe. I depressed the pedal by hand and watched the action; my pedal does not hit the cylinder.
Old Mar 20, 2011 | 03:25 PM
Stryker305's Avatar
Stryker305
Thx Doug must have been the way the previous owner stepped on the clutch,
When I get down there and depress it by hand one can see how the back of the clutch pedal hits the edge of the cylinder.
A couple of guys have mentioned in another thread there might have been a TSB on this, I plan on taking it in for service thx for all your help
Old Mar 21, 2011 | 08:04 PM
009Mini's Avatar
009Mini
I don't know if it is related, but I had the clutch pedal popping issue... made a popping sound when released. All I know is after 50k miles and the 4th clutch assembly, it no longer pops and actually shifts smooth and predictably.
Old Mar 22, 2011 | 09:42 AM
countryboyshane's Avatar
countryboyshane
This happened to me. The dealer can install some spacers to make sure it doesn't slam into those lines. Mine is perfect now!
Colt45Magnus
Aug 27, 2024 05:03 AM
PsychoRallye
21
Feb 17, 2019 06:08 AM
Shomare
39
Oct 19, 2015 03:33 PM
navybsn
Oct 4, 2015 03:27 PM
Miniwaukee
Sep 29, 2015 09:22 AM
