Suspension Recommend a very aggressive setup
Old Mar 16, 2011 | 11:58 PM
Evasive's Avatar
Evasive
Hello all. I'm looking for an aggressive setup for my car. This car will be used for weekend canyon carving and possibly some track time. What front and rear sway bar would you suggest? What about x braces? Again, this doesn't need to have any consideration for daily driving comfort. Stiff bushings or motor mounts?
Thanks!
Old Mar 17, 2011 | 12:42 AM
luseboy's Avatar
luseboy
The general concensus: 19 or 22mm rear bar, personally i use a 19, and find it perfect. stock front bar, or justa cooper non-sport front bar for street/autoX use (a stiffer front bar only benefits you at high speeds, such as on a dedicated track race car, otherwise it induces understeer). X-braces are supposed to make a fairly noticeable increase in stiffness. powerflex bushings all the way throughout. bsh lower motor mount, tsw passenger side upper mount, powerflex for the rest of the bushings. you might consider the wmw race bushings, ive been looking into these. coilovers, adjustable endlinks, adjustable upper and lower rear control arms, roll center adjusters. this is pretty much as far as you're going to get into the suspension without having to start getting custom parts made. This should make a big increase in handling. hope this helped somewhat.
Old Mar 17, 2011 | 07:30 AM
quikmni's Avatar
quikmni
Pretty much what luseboy said.
I would add Front Adj Camber Plates to the list.
Old Mar 17, 2011 | 09:52 AM
Evasive's Avatar
Evasive
Thanks all. I'm looking at Megan coilovers with the built in camber plates. This is very helpful.
Old Mar 17, 2011 | 10:18 AM
quikmni's Avatar
quikmni
If using camber plates in the front, a 19 or 20mm rear sway bar should be adequate.
Old Mar 17, 2011 | 12:23 PM
cmt52663's Avatar
cmt52663
test safely
it's possible to get oversteer with this combination
tire pressures might matter when all is said and done
just sayin'
neutral is a blast though - but find it carefully is all
with good wheels/tires you should be over 1.1 g in transition
cheers,
Charlie
Old Mar 17, 2011 | 01:25 PM
Agarwaen's Avatar
Agarwaen
Another thing, Cabrio front braces. The general consensus is they provide minimal(if any) increase in front end stiffness. But they cost about $30 and bolt on in minutes.
If you are going to AutoX/race an LSD will give major difference.(while it is not a suspension item. It is one of the biggest Benefits when trying to improve your speed out of corners.
Old Mar 17, 2011 | 06:45 PM
luseboy's Avatar
luseboy
oh ya i forgot the camber plates. lol. also, i run 15" wheels, and they're the most agressive. be ready to scrape if you go this route. im at stock height and i still do. just gives me an excuse to dump it... im gonna be scraping anyways lol
Old Mar 17, 2011 | 07:36 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
An aggressive setup you want is mainly going to depend on your budget.
But there are a few MUST Do items I would start with. Front control arm bushings wear out and will last much longer.
Also a rear sway bar, no matter what setup you do the sway bar will make the biggest improvement.
Then a set of hsport rear camber links, that way when you do lower it you can get that camber and alignment dialed in.
Fordgt4
Oct 10, 2015 10:42 AM
martinb
Oct 7, 2015 05:00 PM
Jerome R Jr W
Sep 29, 2015 11:42 AM
daviday
Sep 25, 2015 01:31 AM
potterstein
Sep 11, 2015 11:45 PM
