Replacement Tires
Old Mar 3, 2011 | 02:45 PM
miniinhd's Avatar
miniinhd
Replacement Tires
Hello Mini Owners & Fans What is a good replacement tire for my 2008Mcs with 17 inch rims no runflat tires please Thanks MINIINHD
Old Mar 3, 2011 | 02:59 PM
slinger688's Avatar
slinger688
Are you interested in summer tires or all seasons? And what do you want to do with these tires?
Old Mar 3, 2011 | 03:12 PM
miniinhd's Avatar
miniinhd
hows about all season??
Old Mar 3, 2011 | 03:19 PM
slinger688's Avatar
slinger688
Continental DWS 205 45 17 for street driving.
Old Mar 3, 2011 | 04:05 PM
etalj's Avatar
etalj
For great performance and actually quite reasonable tire life, and also great bang for buck, the Dunlop Direzza Star Spec Z1 is fantastic
Old Mar 3, 2011 | 04:09 PM
mini on's Avatar
mini on
Check out tire rack for their tire reviews. I went with Yokahama Envigors. I think the Contis and Bridgestone Grids would also be good choices.
Old Mar 3, 2011 | 04:12 PM
slinger688's Avatar
slinger688
+1. Great dry and wet tire.
Old Mar 3, 2011 | 05:17 PM
009Mini's Avatar
009Mini
The Conti DWS look small. I'm running 215/45-17s on mine and they still look like they could go another size larger (my gallery pic shows them on my car). But they are great tires... my last set still had some W showing with over 30,000 on them. I just put a new set on this week... huge improvement over the Michelin winter tires I've been running since November.
Old Mar 3, 2011 | 05:26 PM
etalj's Avatar
etalj
frighteningly good in the wet actually, forgot to mention that.
Old Mar 3, 2011 | 05:37 PM
slinger688's Avatar
slinger688
Yup, fantastic in the rain. That why I use them exclusively as my wet tire on the track.
But they are not all seasons. And they do get a little greasy when you heat them up too much.
Old Mar 3, 2011 | 06:00 PM
etalj's Avatar
etalj
Definitely one thing I noticed, they don't like to be too hot.
Old Mar 3, 2011 | 07:24 PM
slinger688's Avatar
slinger688
Great autoX tire.
I have gone through 4 sets of tires already, two sets of z1s. For the street, I still like the comfort and quietness of the conti dws and it is pretty good for all seasons.
Old Mar 3, 2011 | 07:53 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Tire size
205/45-17 is OEM stock and good choice.
215/45-17 is alternate size and slightly larger/taller than stock but OK.
Both with fit stock wheels and stock suspension but if you are lowered then 205/45-17 gives more clearance.
If you have any snow then All Season tire is best.
If you have street only driving and want longer tread life then All Season is best.
While Dunlop Direzza Star Spec Z1 is a very good performance tire (Extreme Summer tire) it is overkill for street driving and will wear fast about 12K+ depending on how you drive. Not for any snow.
In Ultra High Performance All Season tires:
Continental ExtremeContact DWS is the tire of choice dry, wet, or snow.
205/45-17 $109
215/45-17 $115
540 treadwear 20 lbs each
Tests
http://www.tirerack.com/tires/tests/...t.jsp?ttid=124
Bridgestone Potenza RE960 AS
215/45-17 $158 each, 25 lbs each, 400 treadwear
Yokohama AVIDENVigor (W)
215/45-17 $107 each, directional tread design
540 treadwear 24 lbs each
test-
http://www.tirerack.com/tires/tests/...y.jsp?ttid=134
gmonde
Sep 8, 2015 06:37 AM
Colt45Magnus
Sep 7, 2015 10:47 PM
Powershift
Aug 16, 2015 05:14 PM
JamJam43087
Aug 16, 2015 02:02 PM
sabjcw
Aug 14, 2015 07:40 AM
