Summary of Problems in 3 Years.
Old Jan 29, 2011 | 04:58 AM
lalaboi's Avatar
lalaboi
Just to share with all NAM friends. These are the number(S) of major fault I encountered with my MCS since 2007 till today. I hope only to provide some guidance to fellow owner of faults I encountered and the resolution.
Problem 1:
Clutch slip and grinding sound with burnt smell when engaging first or second gear.
Solution:
Sent to dealer, was told pre 07 batch has foul designed clutch. Replaced the whole clutch system. Warranty covered, Lost of usage: 2Week
Problem 2:
Radiator Leakage, No pre-warning from vehicle.
Solution:
Sent in my car to dealer. Replaced coolant pump and seal. Warranty Covered. lost of usage: 1 Week
Problem 2:
Turbo power cut. Engine critically loss in power. Hesitating acceleration initially. After awhile, turbo totally cut with no boost. CEL light up.
Solution:
Sent in to dealer again. Replaced high pressure fuel pump. Warranty Covered, Lost of usage: 1.5 Week
Problem 3:
Engine oil leakage. Sent to dealer, asked to monitor as it is not critical. Continue to drive and leak worsen. I lose half engine oil in 1 week. No warning light at all as it hasnt hit the critical level.
Solution:
Sent in to dealer. Replaced oil pan gasket. No warranty. Lost of usuage: 1 Week. Total cost: 500+USD
Problem 3+:
Continue oil leak. Problem 3 not solved. This time Engine lost power when accelerating, the car feel sluggish during all rpm with strange howling sound at high rev. Idling sound is loud with slight knocking, turbo did not cut. No warning.
Solution:
Sent in to dealer for further investigation. Found that Engine top gasket leak, Cylinder seal leak. over Hauled engine, replaced all engine gaskets, piston seal, cylinder seal, high tensioner. BMW covered all parts. I paid 50% labour. around 500+USD. Lost of usage: 7 Week.
Problem 4:
knocking and hesitating acceleration at 2-3krpm. worst when on load. high Rev is good. No power loss. When idling after car is hot, heard soft single intermittent chipping sound. sounds very short screeching sound. I heard the water pump problem, but it doesnt sound like that. Unknown what is the problem.
Solution:
No solution yet, I changed the spark plug and belt and it improved abit. problem persist. yet to send in to dealer.
No high performance mod on car. I am very scared of driving the car now. problem seems to float very often. I bought the car at around 95-100k USD in Singapore. Yes car over here is expensive and yet I am constantly having problem with the car. MINI is enjoyable if it doesnt have so much problem. There's still some small problem I did not list. I will subsequently update the problem if it comes to my mind.
Old Jan 29, 2011 | 06:11 AM
Peanut61's Avatar
Peanut61
thanks for all the great info!
Old Jan 29, 2011 | 06:44 AM
silkcut's Avatar
silkcut
Wow. That's quite the list!
Thankfully mine is very short. A fog light bulb that got water in it, and a faulty engine temperature switch. (3 years, 64K miles.)
I'd like to get another Mini, but reading some of the problem posts here on the forum makes me a little hesitant. I've had very good luck with my Mini, yet still......
Old Jan 29, 2011 | 07:17 AM
maacodale's Avatar
maacodale
Got ya beat! The sons 07 MCS is having a motor replacement at 80K miles even after being maintained well above what MINI suggests. Carbon buildup and stretched timing chain are part of the issues. Also had the high pressure fuel pump and well as a complete sun roof replacement.
Just wondering if I have this to look forward to on my 09 Clubman S.
Good luck!
Old Jan 29, 2011 | 08:59 AM
lalaboi's Avatar
lalaboi
Yea, it's luck thou. I doubt late 09 and above model will have such a list of problems as 07 model is the pioneer model for R56. I just hope MINI owners have a better view of most common problems which happened to me and attend to theirs when early syntom arises.
Yea, it's not easy to upgrade our vehicle here in Singapore as most of our vehicle is on finance, giving that our MCS R56 cost almost 100k USD.
I envy you guys. =)
Old Jan 29, 2011 | 11:28 AM
Capt_bj's Avatar
Capt_bj
List of problems with my bought new off the lot 07-S
needed new tires at 30,000 miles . . .
service done by the book / computer up to now . . .
Old Jan 29, 2011 | 12:53 PM
MCS Fever's Avatar
MCS Fever
Hint: Don't let your oil get below the dipstick minimum.,,,
Old Feb 1, 2011 | 12:36 PM
bettehead's Avatar
bettehead
Very helpful--thanks. I have an 09 MCS and just had another CEL issue that I'm going to have the car towed to the dealer for (I posted in another thread).
Do the MCSs ever get to a point at which they're fairly care free???
Old Feb 1, 2011 | 04:39 PM
Capt_bj's Avatar
Capt_bj
yes
both of mine have been since I drove them off the lot . . .
they went to the dealer when the computer said ....
Old Feb 1, 2011 | 05:33 PM
bettehead's Avatar
bettehead
^ and it's an S??
Old May 2, 2011 | 03:44 PM
Performance Angst's Avatar
Performance Angst
Why wouldn't the oil pan gasket failure be covered under the warranty?
embiggenedmini
Oct 15, 2015 12:36 PM
KeziaPurrs
Sep 25, 2015 12:29 PM
tgoodspe
Sep 3, 2015 11:16 AM
ki7hy
Aug 12, 2015 07:07 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
