Anyone using Redline tranny fluid?
Old Jan 5, 2004 | 10:01 AM
ball7068's Avatar
ball7068
I have several friends that swear to using the Redline MT-90 or MTL fluid. They say that its helped make their tranny smoother. Anyone had the same experience with the Mini? If so, which are you running - MT90 or MTL
Where approximatly is the drain/add plug? Is there a how to on this?
Thanks,
Erik
Old Jan 8, 2004 | 11:23 AM
pinz1974's Avatar
pinz1974
I e-mailed Redline several months ago and asked what their equivalent is to the stock mini trans fluid - MTL. I bought two quarts but haven't put it in yet. I did spot the drain plug under the front left corner of the car when doing some other work put haven't sighted the fill port yet.
Old Jan 8, 2004 | 05:31 PM
kenchan's Avatar
kenchan
im always hesitant to try aftermarket tranny oil as it deteriorates much
faster than factory. Let us know how you like it. :smile:
Old Jan 9, 2004 | 11:22 AM
apexer's Avatar
apexer
I put Redline MTL in 96 Accord a number of years ago. Made shifting much smoother especially on cold winter mornings. Before MTL, when very cold could hardly shift 1st. to 2nd. until trans warmed up. After MTL, no problems.
Old Mar 21, 2004 | 10:06 AM
MiniPilo's Avatar
MiniPilo
>>Thanks,
>>Erik
You are going to have to remove the heat shield near the tranny. Remove the lower plug which is the drain plug. Then remove the plug that is above and to the left. once this is done, allow the fuild to drain completely. Re install the lower drain plug, and torque to 43 NM. Then pour in the Transmission fluid in the filler hole until it over fills, then allow it to drain until level with the plug hole. Reinstall the filler plug and torque to 43 NM. Then you are done.
Old Mar 22, 2004 | 06:42 AM
Ryephile's Avatar
Ryephile
I put Redline tranny fluid in my Bimmer, and it made the shifting more notchy and clunky.....until the fluid warmed up. Not butter smooth all the time like the stock BMW fluid.
$0.02
Old Mar 22, 2004 | 06:43 PM
early_apex
I picked up a beater 528e several years ago and thought the synchros were shot, but Redline fixed/covered up whatever was causing the problem. Had it in a 635 and in my current 98 Maxima with good results. I plan to put it in our Mini when I get around to changing the oil. Been very happy with it every time I've used it.
Old Mar 23, 2004 | 03:23 PM
pocketrocketowner's Avatar
pocketrocketowner
Only one gear oil is approved for both manual transmissions on the Cooper, Texaco MTF 94. Kind of a short list.....
Old Mar 23, 2004 | 04:35 PM
kapolani's Avatar
kapolani
I'd actually remove or at least loosen the FILL HOLE FIRST.
You may be able to get the drain plug out, but you're SOL if you can't get the fill hole opened.
Old Mar 23, 2004 | 06:04 PM
mattcoon's Avatar
mattcoon
excellent advice!! fill hole first, in case you have too much trouble. I was able to access both plugs without removing any shields. I had to rig a longer hose to reach from the top of the engine to the fill plug, though. All you need is an 8mm hex socket and a long hose for the fill.
PsychoRallye
21
Feb 17, 2019 06:08 AM
mni928
Nov 9, 2015 07:38 PM
vulkandino
Oct 31, 2015 08:29 PM
schr5530
Oct 1, 2015 05:11 PM
bahman
Sep 30, 2015 01:59 PM
