Looking for a replacement hood
I have a 71 Austin mini that has a fiberglass hood with no reinforcements and the gelcoat is cracking causing the paint to crack and chip. I'm located in southern Indiana and looking for a steel replacement.
Also, it's a MK1 hood/bonnet without the lip.
ummm
well maybe like me your original steel has been replaced by glass in the MK1 configuration.
You can get a steel MK1 bonnet from just about any decent Mini parts dealer.
Try Seven
http://www.7ent.com/detail.cfm?pageid=3660
and MiniMania for starters http://www.minimania.com/web/Item/24A1182/InvDetail.cfm
Try Seven
[quote=Capt_bj;3189648]ummm
/quote]
BUT a mk3 body has different hinge location to a mk1 body see pics above....DERRRRR
/quote]
[quote=mk1leg;3189651]
only matter if you use hinges . . .
mine is pinned on as seen in the picture
Ok, my mini body still has the mk3 hinge locations, but the hood/bonnet is pinned at all 4 corners...
I'd just assume keep it that way as far as the hood pins. Thanks for the education on mk1/mk3 as i'm new/newer to classic mini's.
So .. you have steel fenders but a glass bonnet that's pinned in?
I have glass for everything front of the seams . . . well 'cept the electrics and the grill of course. But the fenders are replaced by what most install as a flip front, with a sep' bonnet piece.
The bonnet comes off in seconds and the whole front clip comes off in about 2 minutes
Yea, that's what I have. The fenders were also welded/filled and de-seamed, but they forgot to do the rest of the car at the same time. My guess is there was a dent/dents and that was the cheapest fix...
Interior/Exterior Need Help With Exterior Decisions (05' MCS PHM/W)
boostedhaze
Jan 2, 2018 07:26 PM
O4mcs
Aug 10, 2015 10:22 PM
bctf1
Aug 6, 2015 12:55 PM
