R56 Rear Brake Light Bulb Replacement
Old Oct 15, 2010 | 07:24 PM
kiyo21's Avatar
kiyo21
My rear brake light just recently burnt out. I went over to Kragen to get a replacement. According to their computer, a 2007 Mini Cooper S can use a Sylvania 7528 light bulb that they carry for the rear brake lights. The problem is that its a dual filament bulb, not a single filament bulb which is what my Mini uses. I believe the older models (05/06) used dual filaments but not the 07 and newer I guess. Anyone else have this issue? What bulb did you guys use as a replacement? Thanks.
Old Oct 15, 2010 | 07:50 PM
richardsperry's Avatar
richardsperry
The replacement blub is a 21w/5w (w5w blub) Brake light blub
Old Oct 15, 2010 | 08:12 PM
strobeyprobey's Avatar
strobeyprobey
The brake light bulbs are dual filament.
Old Oct 15, 2010 | 09:46 PM
kukaepe's Avatar
kukaepe
You might also look at the "bayonette pins" around the outside of the bulb. I believe the pins are not directly opposide one another like those used in US vehicles (1034/1157). The part numbers for the correct bulbs will probably be a different number like the 75XX number listed above.
Old Nov 24, 2011 | 02:09 PM
genik's Avatar
genik
hi guys
1. is there a video on how to make this rear bulb replacement? i wanna make the replacement on my own but no idea how
2. what does "dual filament" mean?
Old Nov 24, 2011 | 07:09 PM
klricks's Avatar
klricks
Originally Posted by genik
hi guys
There are step by step instructions with pictures in your owners manual.
A dual filament bulb is 2 lights inside one bulb. Usually one filament will be the tail light and the other will be the brake light. A DF bulb has 3 contact points. 1 for each filament and a base grounding point which is common to both.
Old Nov 25, 2011 | 01:42 PM
genik's Avatar
genik
1. ok ill see in the owners manual although seems strange cause i havent really seen anything like this in there but i may be wrong ill check again
2. do u think it will be worth it to make a replacement with a led bulb, is there such a bulb for this case, a led bulb?
Old Nov 26, 2011 | 07:49 AM
klricks's Avatar
klricks
Please tell what year you have or add that to your signature.
There may be LED bulbs I don't know? One thing you have to look out for with LED's.... They draw so little power that the computer may think that a bulb is out and give you a false warning on the display.
Old Nov 26, 2011 | 10:26 AM
genik's Avatar
genik
its a R56 '08
regarding the led bulbs, has anyone put leds on his mini?
Alkaidovich
Jan 30, 2021 01:35 AM
Dec 23, 2015 10:36 AM
Terry Gallentine
Aug 11, 2015 03:31 PM
