dead battery how to open trunk ?
Old Sep 27, 2010 | 08:22 AM
u68423's Avatar
u68423
Dead battery due to ps fan not shutting off. How do you open the trunk to get the battery out ?
Old Sep 27, 2010 | 08:36 AM
MCS Fever's Avatar
MCS Fever
No trunk on a MINI. Now the boot latch is all electric - so it most def will not open with a dead battery.
See last post here for where the cable release must be...
https://www.northamericanmotoring.co...k-release.html
Old Sep 27, 2010 | 08:37 AM
firenewt's Avatar
firenewt
I've used a battery charger to provide power when this has happened to me.
Kevin
Old Sep 27, 2010 | 09:06 AM
makzu's Avatar
makzu
On my mini there is a cable you can pull under the back seat (it pops right up to reveal the cable) to release the boot hatch. Not sure if yours is different. Good luck!
Old Sep 27, 2010 | 10:23 AM
firenewt's Avatar
firenewt
I have to use the battery charger method since my 2002 MCS doesn't have the cable release - even though the specs says it does.
Kevin
Old Sep 27, 2010 | 02:25 PM
Capt_bj's Avatar
Capt_bj
02-S didn't have the cable release (or a jack)
if you don't have a battery charger just hook it up for jumping using the 'special' positive terminal under the bonnet aka jumper box; your electrics should now work
BUT you probably don't need a battery, you need a ps fan so a brute force solution is to leave the back seats down and disconnect the battery when you park the car until the primary problem is fixed.
Once you get it running do a hour or so at highway speed and your battery will come back if it wasn't too nearly toasted b4 this began. Back enuf for a start or two anyway ... once everything is fixed a good day or two of driving if you have an average commute should fully charge your battery - if it is a decent battery now.
OR
simply jump the car to start it, then drive to the battery place and open everything b4 you turn it off . . .
Old Sep 28, 2010 | 06:16 AM
JumpingJackFlash's Avatar
JumpingJackFlash
+1 to Capt BJ's advice.
Old Sep 29, 2010 | 10:55 AM
u68423's Avatar
u68423
Thank's Namer's great site............
carid
Dec 28, 2025 04:11 AM
UncDeo
Nov 4, 2019 04:08 AM
BucksCountyR57
R57 :: Cabrio Talk (2009+)
Sep 21, 2015 05:42 AM
David Eric Rosenberg
Sep 10, 2015 12:34 PM
wildwestrider
Sep 6, 2015 06:18 PM
