Dropped the vent screw!
Old Sep 26, 2010 | 04:59 PM
gar23's Avatar
gar23
Ok i flushed out my coolant system this morning. As i was venting the system using the 2 screws the one on top and the one next to the t-stat. I dropped the tstat screw and i cant find it. What should i do?! Im really worried because i cant drive it without the screw. Should i search around the bay to find the screw or put on another one?!
HELP!!!!!!!!!!!
Old Sep 26, 2010 | 09:25 PM
gar23's Avatar
gar23
bump
anyone?
Old Sep 27, 2010 | 07:41 AM
quikmni's Avatar
quikmni
You might want to check the local autoparts stores to see if they have anything to replace the one you lost. Many cars use similar coolant vent screws so they might have something equivalent. If you cannot quickly find a vent screw you might be able to find a metric screw/bolt that will fit for a temporary solution. I would wrap the screw/bolt with teflon tape to make sure it seals well.
For longer term, you might be able to order a replacement from penskeparts.com or pelicanparts.com. You can use penskeparts.com or realoem.com to determine the part number.
Old Sep 27, 2010 | 06:10 PM
gar23's Avatar
gar23
thanks for the reply. I found a used part, the whole tube, and just replaced it. It was very annoying getting it out but after 2 hours i managed to muscle it out.
Old Sep 28, 2010 | 07:43 AM
quikmni's Avatar
quikmni
Glad you got it fixed.
n0mis
MINI5280
11
Mar 9, 2016 05:04 PM
minimofo
Dec 26, 2015 12:03 PM
Cruzer214
Oct 11, 2015 07:45 AM
kevinlhr310
Sep 27, 2015 02:31 PM
FatherG
Sep 27, 2015 05:12 AM
