Emergency Brake Light Remains Lit
Old Sep 5, 2010 | 04:37 PM
RallyBox's Avatar
RallyBox
2002 mini Cooper s with 84,000 miles.
Recently, after returning to the mini from work and releasing the hand-brake the brake light remained lit. I took it to be checked out and the shop said, "your master cylinder was stuck open." So I went on my way and 2 days later the light has come back on! I should note that when driving 2-miles or more the "DSC disengaged" light comes on.
Anyone have any thoughts?
Old Sep 7, 2010 | 12:26 PM
schatzy62's Avatar
schatzy62
You would be better off to post this over in the Gen 1 section as your cars is an 02 per your statement.
Old Sep 7, 2010 | 01:33 PM
Capt_bj's Avatar
Capt_bj
I smell a skunk
e-brake is mechanical, right? What's that got to go with a master cyl'? And DSC light comming on .... hmmmmm, sounds electrical or two unreleated issues.....
p.s. for Shatz' - you're right and I expect this to be moved quickly. I just reported it by clicking the little triangle icon in first post and giving reason of complaint: GEN1 question. I've found mods to move such a post within the hour typically.....
TADA!!!!!!!!
Old Sep 7, 2010 | 09:45 PM
Calz's Avatar
Calz
E brake light comes on if the brake fluid is low....
Or if the switch on the E brake is bad or the wiring gets cut
Old Sep 7, 2010 | 10:18 PM
s00perc00per's Avatar
s00perc00per
check your brake fluid, your master or slave cylinder could be going bad. (this happened to me and if i remember right it was the slave)
Etrain
16
Aug 5, 2024 04:37 AM
Toolman
Jan 20, 2016 06:50 AM
ryGuyMCS
Oct 20, 2015 02:24 PM
Terry Gallentine
Aug 11, 2015 03:31 PM
