Drivetrain Should I use my 440cc injectors w/o a tune?
Old Sep 5, 2010 | 10:51 AM
firenewt's Avatar
firenewt
I have a set of 440cc injectors that were going to be used with a Jan tune last summer. Fizzgig is down for some clutch repair so I thought I would install the injectors unless they would be too much w/o a tune. My sig indicates the mods I have.
Kevin
Old Sep 5, 2010 | 11:00 AM
checkmate2006's Avatar
checkmate2006
No you need to have tune and it won't run right because the ECU is scaled for the factory 320cc.
Old Sep 5, 2010 | 02:11 PM
Act_04's Avatar
Act_04
I have also heard there are big problems without a tune. Air/Fuel ratio gets all jacked up and the engine doesn't know what's going on.
Old Sep 5, 2010 | 02:24 PM
CRoth's Avatar
CRoth
I have 450's from Jan. I installed them the day of the tune @ the tune. Ian and Jan told me I could install them before and drive to the tune but warned me that my car would run like sh--.
I would wait if I were you. It's about a 20 minute install. Remember to have some grease on hand for the o-rings.
Old Sep 5, 2010 | 02:38 PM
ScottRiqui's Avatar
ScottRiqui
With the 440 cc injectors and a stock tune, you'll be running uncontrollably rich.
The amount of fuel getting to the engine is controlled by the on/off duty cycle of the injectors. With slightly larger than stock injectors and a stock tune, the car's ECU can compensate by using the "fuel trim" to shorten the injectors' "on" cycle to deliver less fuel.
But, the fuel trim can only shorten the "on" cycle by about 20%, and the 440 cc injectors flow 33% more fuel than stock injectors. So even with the fuel trim at its limit, you'll be flowing about 13% too much fuel.
Old Sep 5, 2010 | 03:20 PM
firenewt's Avatar
firenewt
I kinda thought that would be the case. I just hate to have parts sitting around gathering dust. Need to find out if Jan will be in the midwest any time soon.
thanks for your responses,
Kevin
Old Sep 5, 2010 | 07:47 PM
HRM's Avatar
HRM
You can get a remote tune from Jan that scales the injectors and takes into account your mods. Then, when he finally is in your area, for a few more bucks he can tweak it. It Will make you feel good, and it isn't much money, so I say "Just do it"
Old Sep 5, 2010 | 10:22 PM
fishead # 1's Avatar
fishead # 1
injectors
Call Jan~~~~pull your ecu ,send it to him~~ install your injectors (unless he wants to "scale" them~~ re-install the ecu and be HAPPY !! OBEY
Old Sep 6, 2010 | 07:06 AM
firenewt's Avatar
firenewt
Didn't know Jan did this. Shouldn't be surprised, Randy Webb did my tune in this manner. Time to call Jan.
Kevin
Old Jul 11, 2020 | 06:48 PM
Russ Rauscher's Avatar
Russ Rauscher
440 injectors
Hi, Could someone give me Jan's Number or contact info ?,,,I installed GT Tuning 440 injectors in my 05 MCS, and would really like to get a tune,,,Thanks in Advance
Old Jul 12, 2020 | 09:56 PM
Mini_Crazy's Avatar
Mini_Crazy
Jan is a Vendor here on NAM, so no problem posting contact info. Website is http://store-revolutionmini-com.3dcartstores.com/ and his phone number is listed under the "Contact" info at the top of the page. In my experience, the best way to reach him is by phone.
Old Jul 15, 2020 | 01:30 PM
Russ Rauscher
Thank You Very Much
iggi
18
Feb 9, 2026 01:00 AM
Teh
Aug 22, 2022 04:37 AM
Mjimport
Oct 26, 2015 03:42 PM
Manny_cooper
Aug 31, 2015 05:04 PM
bigserb3
Aug 31, 2015 09:54 AM
