Quiet HK volume
Old Sep 1, 2010 | 09:44 PM
burley's Avatar
burley
Quiet HK volume
When listening to the radio, the volume is way to quiet with my HK stereo while the windows/roof are open. If I switch to CD/iphone the volume is much much louder.. usually too loud.
Is there any way to adjust the radio volume other than the volume ****? Anyone else have this issue?
Old Sep 1, 2010 | 11:08 PM
Eric_Rowland's Avatar
Eric_Rowland
Assuming you're using Aux in, there is a separate (relative) volume control for that. IIRC, hold the 'note' symbol, then keep pressing and you'll get to Aux volume - adjust w/volume ****.
Old Sep 2, 2010 | 07:08 AM
burley's Avatar
burley
The Aux is fine, as is CD. Im just talking about the radio. Everything else I can hear fine with the windows down, but whenever I try to listen to NPR or most talk radio its way too quiet at full volume.
Old Sep 2, 2010 | 12:03 PM
Eric_Rowland
Huh - sounds strange. Is your NPR on AM or FM?
Old Sep 2, 2010 | 09:53 PM
burley's Avatar
burley
FM. Really, its all AM/FM radio. No one else has an issue with the radio being to quiet?! Its pretty bad, hard to miss...
Old Sep 2, 2010 | 10:56 PM
ScottRiqui's Avatar
ScottRiqui
Try a stronger local FM station and see if the problem persists. It may be that the station hosting your talk radio just isn't very loud.
Also, set you bass and treble controls to mid-scale if they're not already there. Setting the bass and/or treble much above mid-scale will reduce the overall volume of the H/K system pretty significantly, and it might be more noticeable on the radio than on the other sources.
Old Sep 3, 2010 | 07:43 AM
burley's Avatar
burley
Its all the stations, AM / FM. Overall, just seems very quiet. I used to live in Chicago, and it was the same there too. Must be the stereo...
Old Sep 9, 2010 | 06:43 AM
burley's Avatar
burley
Anyone? Aux / CD is fine. All AM/FM radio is too quiet, no matter what station in Chicago. Any ideas? Can most of you hear the radio with your windows down?
Old Sep 9, 2010 | 09:04 AM
nervous's Avatar
nervous
I had HK in my '03 & have it in my current '06. No huge volume differences between radio and cd. Can hear both with windows down. Of course, cd always sounds clearer/louder.
Old Sep 10, 2010 | 09:56 PM
rgc0233's Avatar
rgc0233
Its all in the way its set up. After reading the attached info, my system was much, much better,
http://www.in2guitar.com/minihkreview.html
Old Sep 12, 2010 | 06:02 PM
burley's Avatar
burley
Thanks! That was a good read, I figured out that if I have my bass and treble all the way up, it limits your peak volume. I flattened it out, and instantly louder.
Thanks so much!
Old Sep 12, 2010 | 06:12 PM
ScottRiqui's Avatar
ScottRiqui
I guess you missed post #6 -
Also, set your bass and treble controls to mid-scale if they're not already there. Setting the bass and/or treble much above mid-scale will reduce the overall volume of the H/K system pretty significantly, and it might be more noticeable on the radio than on the other sources.
Glad to hear you got it sorted out!
Old Sep 13, 2010 | 06:33 AM
burley's Avatar
burley
Sorry, missed it somehow. Thanks though!
Old Sep 13, 2010 | 09:44 AM
Walt's Avatar
Walt
Do you have the Speed Sensitive volume control? If so, what is its setting (try other settings?). Just guessing that possibly you have it set to greatly reduce the radio's volume when not moving.
While I have a H/K radio, it doesn't seem to have the Speed Sensitive volume control feature as mentioned in its manual.
Old Sep 13, 2010 | 12:38 PM
Cole9953's Avatar
Cole9953
in my 06 the Cd and fm are allot louder than the ipod, with the windows down at speed i cant hear it, really annoying.i have tried holding the note key and looking for an aux volume but havent found it yet. I'll have to double check my bass treble, and mid settings and make sure none of them are way up.
2011minnie
Tires, Wheels, & Brakes
Dec 10, 2015 10:36 AM
Jim Ferrell
Oct 6, 2015 08:09 AM
2011minnie
Sep 27, 2015 10:44 AM
Sailorlite
Sep 4, 2015 07:03 PM
