What do do about 12mm vs 14mm lugs
Old Aug 17, 2010 | 10:16 PM
ThumperMCS's Avatar
ThumperMCS
So I've had a set of 18" Exel TZ-10's laying around for MONTHS:
...that are just dying to be put on my car, but I have an R56. The TZ-10's are drilled for a 12mm lug bolt, but as we all know the R56 has 14mm.
I know this topic has been semi-discussed before, but I want some advice/help
Originally I was just going to have the holes machined out to 14mm...simple. But upon further inspection, the tapered part of the stock lug bolts won't fit into the holes, even if they were drilled out to 14mm. So I'm guessing I'm going to have to go to a stud conversion kit. Which got me thinking, if I have to convert to studs, why don't I just get a 14mm->12mm stud kit, which I used to see around here. Interestingly enough I can't seem to find them anymore.
So I guess my question is what should I do? Should I:
A) Not have the wheels drilled, and try to find a 14->12mm stud kit. How safe are these anyway? I don't know if I trust them, and have heard never to run studs like this as they are weaker than if you were to just have a single sized stud...
B) Still have the wheels drilled and find a 14mm stud kit for them
Any advice would be appreciated.
Old Aug 17, 2010 | 11:56 PM
10Zero's Avatar
10Zero
Personally, I'd tap em to 14mm and then get a set of aftermarket chrome lug bolts like those sold through discount tire direct. The cone seat is smaller than the oem bolts, making for a fit into the smaller holes.
http://www.discounttiredirect.com/di...riesWheels.jsp
But it's a personal choice and decision.
Old Aug 18, 2010 | 12:49 AM
ThumperMCS's Avatar
ThumperMCS
Thanks...its more work and money, but in the end I think I'd be more comfortable going that route.
Old Aug 18, 2010 | 09:52 AM
minirage's Avatar
minirage
if you are looking for a 14mm to 12mm stud kit, Way Motor Works sells the TSW stud conversion kit. http://www.waymotorworks.com/m14-to-...rsion-kit.html
OPC's Avatar
OPC
RATTUS Deserticus
Way lists the conversion kit: M14x1.25 to M12x1.5. I've been running these with 5mm spacers for about 6mths without issue.
Edit: Nice synchronized posting with minirage, no?
Old Aug 18, 2010 | 09:55 AM
minirage's Avatar
minirage
yup, that's pretty funny
Old Aug 18, 2010 | 05:03 PM
Short Wait's Avatar
Short Wait
Go with the tsw stud kit from way. I've been running this set up for two years now without any issues whatsoever on my 08 mcs.
Old Aug 18, 2010 | 07:39 PM
ron-s mini's Avatar
ron-s mini
You gotta remember all 2002-2006 MINIs had 12mm bolts. From my experience a high % of the track MINIs use the 12mm studs as it so much easier to change wheels. I have the TSW 12mm studs on the street and track without any problems.
Old Aug 23, 2010 | 07:56 AM
jsargevt's Avatar
jsargevt
Aw man!
I just saw this thread yesterday and made me think: hey what about my nice SSR type-c wheels I picked up the other week. The previous owner said they were on a MINI and I saw looked like the fitment was a match.
However, I was caught out by the 14mm vs 12mm lugnut issue. I thought i had done all my homework yet you can see that I missed this critical piece of info.
Now I need to decide: keep them or get a stud conversion? Not sure which to do right now.
Old Aug 23, 2010 | 08:56 AM
mini_macky's Avatar
mini_macky
i'd definitely go for a stud conversion rather than have the wheels drilled. the TSW ones that Way has is out of stock at the moment. has anyone tried the studs from Evasive Motorworks?
http://www.evasivemotorsports.com/me...HEELMATE-STUDS
Old Aug 23, 2010 | 08:33 PM
Calz's Avatar
Calz
Stud kits are safe... and they are nice because you can add spacers and adjust offset very easy to find the fit and stance you like. Just buy a high quality kit with high grade studs. I believe the factory studs are grade 10.9
Old Oct 2, 2010 | 03:20 PM
bluefox280's Avatar
bluefox280
This is a great thing to hear as I'm considering a wheel package that requires M12's instead of M14's.
- Erik
freckles81
Jan 15, 2017 06:33 AM
theblackfalcon
Oct 19, 2015 05:22 AM
Sep 18, 2015 12:45 PM
papawhiskey
Sep 14, 2015 05:47 PM
Sep 10, 2015 10:52 AM
