sc removal
Old Aug 13, 2010 | 03:10 PM
works usually's Avatar
works usually
sc removal
Wrenches,
Can SC, waterpump, be removed w/o pulling intake manifold off?
thanks to all who've made my years of lurking so informative!
I asked local mini tech what life of sc oil was usually, he said no oil, its dry.
OMG.
Old Aug 13, 2010 | 03:44 PM
HRM's Avatar
HRM
I bought an oil kit on ebay with a syringe and spouted bottle which looks like it will let you leave the thing on and change the oil.
With that said, I plan to take it apart and to inspect it and replace the water pump while there. ( I have a new waterpump already that I will return if I don't need, but the old one better be perfect for me to leave the it in.) I did a bunch of research and didn't get a manifold gasket which makes me think we don't have to remove it.
This thread was Good.
https://www.northamericanmotoring.co...02-post71.html
Old Aug 13, 2010 | 03:58 PM
MINI33342's Avatar
MINI33342
You can't replace the water pump only the gears. It is part of the SC body.
It can be removed w/o removing the intake manifold.
Old Aug 13, 2010 | 04:18 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
photo of supercharger core no pump attached...............
www.Penskeparts.com
#1 - RMFD WATER PUMP part no. 11517520123 - $229.00.
Old Aug 13, 2010 | 04:28 PM
MINI33342's Avatar
MINI33342
Yep.....had it backwards.
Old Aug 13, 2010 | 04:43 PM
-=gRaY rAvEn=-
Moderator
Old Aug 14, 2010 | 06:55 AM
works usually
thanks folks, good help and nice pics.
Old Aug 14, 2010 | 07:44 AM
CrazyIvan's Avatar
CrazyIvan
If you change the water pump you will need 2 of the #2 o rings in that diagram. Also the new water pump must have been slightly longer so I had to leave the #7 bolts loose might the SC up and then tighten the #7 bolts down.
Old Aug 14, 2010 | 08:12 AM
ZippyNH's Avatar
ZippyNH
The SC oil is sold at GM...they have lots of EATON SC in their cars....
UncDeo
Nov 4, 2019 04:08 AM
BRracing
Oct 24, 2015 10:07 PM
Sep 2, 2015 11:15 AM
Sep 2, 2015 09:05 AM
broncobuddha
Sep 1, 2015 06:32 PM
