Burnt secondary thermostat
Old Jul 22, 2010 | 03:37 PM
freeman727's Avatar
freeman727
I need some advice from those of you who are mechanically inclined. I started my car this morning (it was around 82 F this morning) and after gentle driving for less than a minute my R56 S started fuming from the hood with an electrical and rubber smell coming through. The coolant and oil level were normal. I brought it to Hassel Mini and was told that the turbo pulley rubbed on the secondary thermostat and caused a small electrical fire. The rep stated that nothing was damaged and that only the thermostat needed replacement. I'm a little skeptical and worried. What should I do? My warranty doesn't run out until next April but I don't want a disaster while driving the vehicle!
Thanks for all of your help and input.
Old Jul 22, 2010 | 04:14 PM
MINIdave's Avatar
MINIdave
I think you're a little bit confused about what they told you, Turbos don't have pulleys.......
Other than that I think I'd trust what the fixed......
The other thing I wonder is why you drove your car with smoke coming out from under the hood. Most people would call MINI for a tow truck.....
Old Jul 22, 2010 | 04:23 PM
freeman727's Avatar
freeman727
I know it was dumb but the car stopped smoking. I also had a lot of time constraints. I'm at work as I type. I was merely quoting the customer rep.
Old Jul 22, 2010 | 08:04 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
I would go back to the dealer and have the SA go over what was burning, and what the fix was.
What does the customer copy of the work order state ?
Old Jul 22, 2010 | 08:20 PM
Dr Obnxs's Avatar
Dr Obnxs
Someone else posted...
about wiring issues with the aux water pump for turbo cooling. Sounds like something to keep an eye on.
Matt
Old Jul 24, 2010 | 06:35 PM
freeman727's Avatar
freeman727
I'll try to find the forum member with the same issue.
I could not get the google docs upload to play nicely with this forum, so I've typed from my receipt:
TEST DME FAULT CODE 2F37 AUXILLARY WATER PUMP FOR TURBO CHARGER ACTIVATION FAULT CURRENTLY PRESENT. CHECK AND FOUND AUXILLARY WATER PUMP FOR TURBOCHARGER BURNT, CONNECTOR AND WIRES ALSO BURNT. REMOVED FRONT BUMPMER REPLACED AUXILLARY WATER PUMP FOR TURBOCHARGER, REPLACED CONNECTOR, REPLACED PIN AND WIRES THAT WAS BURNT CHECK AND FOUND POWER AND GROUND AT AUXILLARY WATER PUMP AFTER REPAIRS - BLED COOLANT SYSTEM REINSTALL FRONT BUMPER RESET ADAPTATION AND CLEAR FAULTS
Old Jul 24, 2010 | 09:47 PM
Dr Obnxs's Avatar
Dr Obnxs
They fixed all that was broken...
I'd take a look around there and see if there is a place that can wear and short. If so, protect it or make sure it can't rub so that this doesn't happen again.
I think the reference to the other similar fault may have been in one of the spontaneous engine bay fire threads.
Matt
JHolland
Sep 24, 2020 08:20 AM
mni928
Nov 9, 2015 07:38 PM
Cruzer214
Oct 11, 2015 07:45 AM
tag1260
Sep 29, 2015 03:53 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
