Cannot get Above 3000rpm...Vibrates Bad
Old Jul 19, 2010 | 08:59 AM
Rikay's Avatar
Rikay
hey all guys...
ii would really need some help... recently driving back home i shifted to 2nd gear and the rpm didnt wanted to go past 3000...the throttle i had pressed til WOT and the car seemed DEAD LOOSING POWER and just sound....Vibrates and shivers in every gear above 3000rpm...i pressed it hard and it could not even reach 4000rpm
and then i came home and left the car and started in morning then it could not start at ALL...i tried ignition 10times and maybe in the 15+ try it started hardly and the System giving me Battery light cz of it...
Modifications = 15% alta pulley,Alta lightened Crank,Alta Air Intake,Msd,Magnecor 8.5mm leads and Brisk Racing Silver Plugs...
The car was fine until this turned up all of a sudden...
Please Help
Old Jul 19, 2010 | 09:59 AM
ALTA_Jarid's Avatar
ALTA_Jarid
How long ago did you do your modifications? It almost sounds like you spit the belt off. Take a look there first.
Old Jul 19, 2010 | 02:12 PM
Rikay's Avatar
Rikay
it has been hardly 5000miles...
Checked the wires and the MSD and the plugs but nothing Wrong...but YES about a week back My TENSIONER have failed and it gives rattling sound
...im still not sure...been 3days i drove with rattle Belt tensioner and suddenly it became like this...
IS it because of the failed rattling sound of tensioner???
My mechanic said its more likely to be some problem with Fueling !!!
Old Jul 19, 2010 | 02:27 PM
ALTA_Jarid's Avatar
ALTA_Jarid
MIGHT be alot of things. Did you look to see if the belt was still on?
Old Jul 19, 2010 | 02:35 PM
Rikay's Avatar
Rikay
yea belt is still on and running fine...checked it...
it accelerates madly at WOT also bt after 3000rpm looses all the power and then there is sound only for supercharger whine with bad vibration....hardly will go 5000rpm i doubt...or mayb 4500rpm
Old Jul 19, 2010 | 10:21 PM
KC Jr 54's Avatar
KC Jr 54
How many miles are on your car and are there any fault codes ?
Old Jul 20, 2010 | 05:55 AM
ZippyNH's Avatar
ZippyNH
Makes me wonder if the crankshaft harmonic dampers is going...can you see if it is wobbling....
They often wobble as the rubber shreads, then fail...they start to slip...throw a few codes, and the alternator will not bevturning at full speed due to a slipping belt....getting to higher rpm's would be hard too....
Any codes?? Sounds? Smells?
Old Jul 20, 2010 | 06:09 AM
Rikay's Avatar
Rikay
me dont have a scan guage bt im getting one soon...
there is no smell but the exhaust wrobble...
im gna check for that and let u guys know...thank you
Sidewalksam's Avatar
Sidewalksam
are you leaking any fluids? No codes (service Engine light)? There are a number of things that could be the cause. A bad supercharger, failed motor mount?, clogged exhaust creating back pressure and bogging car at higher RMP?
Does the car rev above 3K in neutral? if you have the same problem have someone look at the engine when you apply gas.
to check the alternator function (and overall belt driven problem) check the voltage across the battery with the car on. should be 13.5-14.5V
good luck
Old Jul 20, 2010 | 06:11 AM
Sidewalksam
do you mean sound or movement? this may be a clogged CAT the threshold of 5K is typical for other cars. try finding a test pipe or disconnect the CAT from the manifold and see if you rescue. if so then replace CAT
Old Jul 20, 2010 | 08:15 AM
Rikay's Avatar
Rikay
Checked the pipe too and is fine...
it is the Fuel pump...the filter is fine but the pressure is low...we ran the car on carburetor and it started in a glance and the rpm revs just perfect...
seems like the fuel pump was not giving out much pressure fuel...
now i wanna buy a fuel pump...there is one at Partsgeek.com and its some VDO fuel pump assembly...is it ok or just the oem one?
Old Jul 20, 2010 | 08:41 AM
ZippyNH's Avatar
ZippyNH
.....we ran the car on carburetor and it started in a glance and the rpm revs just perfect..
seems like the fuel pump was not giving out much pressure fuel.......
That is a neat trick.....
Old Jul 20, 2010 | 08:49 AM
Guitarfrk75's Avatar
Guitarfrk75
I was just thinking that...
Old Jul 20, 2010 | 08:50 AM
Rikay's Avatar
Rikay
LOL Yea
navybsn
Oct 5, 2018 04:42 PM
schr5530
Oct 5, 2015 08:28 AM
schr5530
Oct 1, 2015 05:11 PM
M7Speed
Oct 1, 2015 07:05 AM
pkillur
Tires, Wheels, & Brakes
Oct 1, 2015 03:59 AM
