Navigation & Audio Having a little bit of an issue with speaker install..
Old Jul 17, 2010 | 02:43 PM
Un0RiGiNaL's Avatar
Un0RiGiNaL
So i just bought infinity kappa perfect 6.1's.
I need speaker spacers, the spacers i have are too big and interfere with the door panel, and the other set of spacers i have are too small and the speaker interferes with the window mechanism.
Does anyone know where i can purchase spacers that fit our wierd-shaped stock location?
Old Jul 18, 2010 | 12:29 PM
madsedan's Avatar
madsedan
I cut mine out of marine grade plywood I had lying around.
Go pick up a 2' x 4' piece of 3/4" mdf fpr $11 at home depot and get cuttin'.
Old Jul 19, 2010 | 09:37 PM
Act_04's Avatar
Act_04
also what I did.
Old Jul 26, 2010 | 05:53 PM
Un0RiGiNaL's Avatar
Un0RiGiNaL
im also having other issues
my amplifier keeps turning on protect when i turn the volume up. i have the ground grounded on my battery ground. all wires ran fine.. whats the issue?
do you guys have issues like this on your minis?
Im not even running a subwoofer, I just have very high power amp and speakers.
Infinity Kappa four amp 125RMS x 4 channels
Kappa Perfect 6.1 100RMS
Kappa 692.9i rears 110RMS
Old Jul 27, 2010 | 05:18 AM
madsedan's Avatar
madsedan
I did NOT ground to the battery, sanded through paint to bare metal and attached my ground to the inner fender, about where the factory amp is located.
The only reason I'd know of that an amp would go into protect mode is if its getting too hot or its pushed too hard. I installed a 50wx4 Alpine in my mini and my MB Quarts are rated at 50w rms and I have no problems, not sure why your 100w fronts would be popping it if its rated at 125w per channel.
Is it wired up at 4ohm set-up?
Old Jul 27, 2010 | 04:15 PM
Un0RiGiNaL's Avatar
Un0RiGiNaL
Well its not getting too hot, my speakers arnt popping no distortion just protect turns on so idk what it could be.
Old Jul 28, 2010 | 08:51 PM
Un0RiGiNaL's Avatar
Un0RiGiNaL
anybody?
Old Jul 29, 2010 | 06:12 AM
madsedan's Avatar
madsedan
Try contacting the dealer that sold you the amp, definitely something up with it. If you bought second hanf then contact Infinity customer support or tech line.
Old Jul 29, 2010 | 01:44 PM
Un0RiGiNaL's Avatar
Un0RiGiNaL
I bought it directly from infinity and its brand new.
woodstudio
Mar 15, 2020 08:28 AM
Teh
Jun 13, 2018 02:59 PM
theblackfalcon
Oct 11, 2015 09:49 AM
jnrjr79
Navigation/Audio
18
Sep 18, 2015 05:51 AM
OutMotoring
Aug 6, 2015 09:32 AM
