R52 wife's top wont open and there is a small cable exposed, what is it
Old Jul 5, 2010 | 04:18 PM
tsidders's Avatar
tsidders
Hi all
I've been reading the archives with how to determine if the cable has broken, I'm fairly certain that the pass cable let go as the pass latch will not release once the roof attempts to more into full roof down position. When trying to figure out what the problem was, I noticed this thin cable sticking out just in front of the roll bar on the pass side. Can anyone advise me on what it is and why it might be showing?
Thanks in advance
Attached Thumbnails wife's top wont open and there is a small cable exposed, what is it-p1010923-800x600-.jpg
Old Jul 5, 2010 | 09:56 PM
JeffreyC's Avatar
JeffreyC
Just by reading the title and not what you posted, I was going to suggest the underwire in one of the cups broke through.
But since I've read the entire post, I suspect that's not the case.
Old Jul 5, 2010 | 10:30 PM
cop1406's Avatar
cop1406
I hate it when I can't get my wifes top open.
Old Jul 5, 2010 | 10:46 PM
Oxybluecoop's Avatar
Oxybluecoop
Looks like a tension cable has come loose as you suspected. There is one on each side. This should be a warranty fix unless your beyond the period. Have a look here for diagrams and part numbers. I also have a PDF on how to replace the cable(s) if you decide to tackle this yourself.
Old Jul 6, 2010 | 05:42 AM
tsidders's Avatar
tsidders
Could that tension cable be the culprit for the roof not being able to retract?
Old Jul 6, 2010 | 06:10 AM
mini_racer's Avatar
mini_racer
She is a Fembot.
Old Jul 7, 2010 | 09:01 PM
chollon's Avatar
chollon
Can you post or send me that PDF? I have been going nuts trying to find why my top will not go past the latches releasing on the second stage of the opening. Hope maybe that file might give me a little in site
Old Jul 14, 2010 | 07:44 PM
Oxybluecoop
R52 Top Cable Replacement.pdf
Old Jul 15, 2010 | 05:04 AM
chollon's Avatar
chollon
Thanks Oxybluecoop.
I will take a look at it this evening.
Old Jul 16, 2010 | 12:13 PM
Cadenza's Avatar
Cadenza
Does Mini have a service/maintenance routine for the convertible top? Considering there's so many moving parts (joints, cable, gears), you would think periodic lubrication is necessary.
Old Jul 16, 2010 | 04:08 PM
brg bob's Avatar
brg bob
His wife may have her "top" locked. Maybe she is mad at him. LOL
Old Jul 19, 2010 | 02:17 PM
chollon's Avatar
chollon
That would be nice to know... I have pulled out the Motor on the top frame and i am going to check the alignment to see if it is off... Maybe I will get lucky. To hot this week to mess with it though...In the 100's all week.
Old Jul 22, 2010 | 12:53 PM
chollon's Avatar
chollon
Well I got very lucky Last night. Sort of. I notices that one of the back windows was slightly down yesterday and it appears to be off track. The bad part is that you really need the top down to do much about this.
I had pulled the tops motor out last week and decided to put it back. Last time I messed with it a screw fell between the seats and I could not get it. Ever since then the top did not work.
Well i got the screw and put everything back and tighten all three screws. I then turned the emergency crnnk slightly and it clicked. This was a new thing.
So the moment came and I hit the button. The first position worked as usual. I then held my breath and tried it. First I heard a bad noise but realized it was that window.Then it unclamped like it had been doing... then suddenly it rose up and retracted.
So all my issues came from a screw...one screw. Make sure if you ever have to remove the motor to mess with those cables that you get all three in and tight. I am so happy now. going to try to get the window resolved tomorrow morning...then road trip...FINALLY
Thanks everyone for your help and ideas!!!! GRNGYNT is topless again!!!!!
Of course it is now 100 degrees out...LOL
Old Jul 26, 2010 | 04:32 PM
Cadenza's Avatar
Cadenza
You could make a song out of this...
Well I got very lucky Last night. Sort of...
So all my issues came from a screw...one screw!!!
Getrieben
Sep 12, 2024 07:03 AM
Getrieben
Aug 17, 2016 06:32 AM
Dec 23, 2015 10:36 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
PatrikKN
Aug 5, 2015 09:10 PM
