R50/53 Service Engine Soon... yay!
Old Jun 28, 2010 | 03:50 PM
Mello_Yellow's Avatar
Mello_Yellow
Recently I had my one ball mod done, and my pulley mod done. Since roughly about that time, I've had my Service Engine Soon light on and off, depending on the luck of the draw when I start my engine.
Here are my concerns:
1. Could it be from the exhaust, or no because it's too far back to have been caught by a sensor.
2. While I wouldn't normally consider the pulley mod as the culprit, it wasn't an easy install for my local shop. Apparently I have a newer style crank thingie, and that meant it needed to be taken off before they could get to the pulley, making the install a lot harder. My concern is that maybe a hose wasn't put on right or something in the engine bay.
Hopefully luck will be on my side and it will only be an O2 sensor or something. Any thoughts of what this could be? Btw, I already checked.. it's not the gas cap. It's on correctly.
Old Jun 28, 2010 | 04:17 PM
Fatherdeth's Avatar
Fatherdeth
Take the O2 sensor off and wipe it with a rag. Don't use any cleaner, just a dry clean rag, preferably a microfiber one. Could be just a little bit of crud is on the sensor.
Old Jun 28, 2010 | 04:47 PM
Achilless's Avatar
Achilless
Resetting the ECU could help, if that wasn't done already.
Old Jun 28, 2010 | 07:04 PM
thulchatt's Avatar
thulchatt
If you don't have a code reader take it to a local auto parts store (AutoZone, etc) and ask them to read the codes. They will not clear the code but you will have more info to work with.
Old Jun 28, 2010 | 07:11 PM
Crashton's Avatar
Crashton
+1 Start with reading the code....
Old Jun 28, 2010 | 10:48 PM
Mello_Yellow
Hmm, didnt know they would do that for me. Thanks guys, I'll do that!
The ECU wasn't ever reset, and I'm curious.. anyone have a picture on where to find the O2 sensor?
I really appreciate the help guys. Anyway to save money on this car, the better lol.
Old Jun 29, 2010 | 02:59 AM
DOT191's Avatar
DOT191
Recently had a new OEM Exhaust System put on our 2003 Mini. Service Engine light came on. Reset ECU & ended up replacing rear O2 sensor. Problem solved.
Old Jun 29, 2010 | 07:48 AM
Raymazing's Avatar
Raymazing
Disconnect battery for a bit... go from there
Old Jun 29, 2010 | 08:30 AM
kazlot's Avatar
kazlot
Go to post 27: https://www.northamericanmotoring.co...to-lean-2.html
for a picture of an o2 sensor and its location.
Hope this helps...
Old Jul 3, 2010 | 01:09 PM
SYG's Avatar
SYG
What is the one ball mod? lol
Old Jul 3, 2010 | 03:31 PM
Achilless's Avatar
Achilless
The one ball mod is basically a cheap way to 1. get a a deeper, slightly louder sound, 2. weight reduction 3. believe it or not, you can feel some more power.
here's a link for a diagram of what is performed to do the mod, http://reviews.carreview.com/blog/mi...haust-upgrade/
I did my oneball mod in my garage, just cut and rewelded, easy to do. most auto shops can do this in an hour If you show them a diagram of what your talking about, and will charge $20.00-100.00.
09R56
Nov 16, 2022 10:49 AM
W0TM8
Dec 19, 2019 07:50 AM
Aug 19, 2015 12:51 PM
Aug 19, 2015 08:22 AM
