Navigation & Audio iTouch mounting bracket from Cravenspeed
Old Jun 23, 2010 | 03:40 PM
Albiecrazy's Avatar
Albiecrazy
I ordered the above from outmotoring. It seems like a simple install - just mount it with the existing bolts on the backside of the tachometer. It's a phillips head bolt - only problem is getting a screwdriver to it - it's tight.
Any suggestions on the right tool for the job?
Old Jun 24, 2010 | 05:30 AM
schatzy62's Avatar
schatzy62
If it did not say in the instructions you really need to take the Tach off the steering column to get to the screws. I don't have instructions for that but if you contact Craven speed directly Kevin (i think that is his name) is very willing to assist customers with that sort of thing.
Old Jun 24, 2010 | 05:32 AM
schatzy62's Avatar
schatzy62
here is a link to instructions that state how to take off the Tach.
This is the instruction for one of the Tach mounted brackets from Craven Speed.
http://www.cravenspeed.com/product_i...-1000-R140.pdf
Old Jun 24, 2010 | 01:21 PM
Albiecrazy's Avatar
Albiecrazy
Yeah, didn't get any instructions in the box (???). And I figured the job required the tach to be removed, but since I didn't have the right torx head, I ended up installing without pulling the tach. You can imagine how that went... But it is on and I do like it. Now I get a cupholder back!
Old Jul 13, 2010 | 05:06 AM
isthar's Avatar
isthar
Hey, those that have this (or similar iphone/ipod mounting kits) -- do any have some kind of quick release mechanism? I mean, who wants to have a arm/holder swinging out above their steering wheel when the phone/ipod isn't there?
Old Jul 13, 2010 | 06:00 AM
Albiecrazy's Avatar
Albiecrazy
I had mine mounted up above the steering wheel, but I have since swung it down - it bounced around a bit up there. Now that the bracket rests against the steering column it does not bounce. And to your question, isthar, it now sits lower and is more discreet and out of the way...
Not the greatest pic, but I think you get the idea...
Old Jan 21, 2011 | 04:31 AM
isthar's Avatar
isthar
Is that the R bracket or one of the others?
Old Jan 22, 2011 | 02:02 PM
Albiecrazy's Avatar
Albiecrazy
I have this:
Cravenspeed Universal "Scissor" Mount Kit.
I liked this one since just about anything will fit in it.
Old Jan 23, 2011 | 06:47 AM
MeepMini's Avatar
MeepMini
Hey there,
I just got one of those scissor mounts. Where did you run the cable for the iphone? or is it bluetooth?
I don't have bluetooth on my mini so I've been trying to find a way to route the cable through the dash or something and down to the aux plug.
Any suggestions?
Old Jan 23, 2011 | 01:00 PM
Albiecrazy's Avatar
Albiecrazy
Originally Posted by MeepMini
Hey there,
I'm not exactly happy with how mine is set up now but it works. I have a Belkin Retractable audio cable. You'll see from the link that the cable winds up inside it. I have the round, retractable part attached just down and to the right of the steering column with a small piece of velcro. This location basically splits the difference between where the scissor mount is located (to the left of the steering wheel) and the aux input. The wire runs up and over the steering column - it's out of the way and I barely see it, but eventually I want it to run up and under the dash.
bahman
Nov 15, 2019 05:45 AM
Sep 11, 2015 01:15 PM
makg
Sep 10, 2015 11:59 AM
USA-RET
Sep 8, 2015 01:50 PM
Sep 4, 2015 02:34 PM
