Interior/Exterior Black'd out N' Yellow'd Out
Old May 11, 2010 | 03:16 PM
plasticknives's Avatar
plasticknives
Bought some Lamin-X for my fogs and had leftover so I decided to do the turn signals as well. In the process, I sprayed the orange bulbs with a thin coat of silver paint. I also Plastidipped my arch lights. What do you all think?
Old May 12, 2010 | 11:13 AM
Act_04's Avatar
Act_04
Fogs and turns look real good. Can't see your arch lights in this pic though...which is great!
Old May 13, 2010 | 06:23 AM
danmay's Avatar
danmay
looks good!
i really want the arch lights for mine, seems like all US modders want to get rid of them and all UK modders want to add em!
Old May 13, 2010 | 06:28 AM
plasticknives
I originally liked the look of the arches, but once I added the yellow, there was too mant colors.
I think I'm going to add yellow Nokya bulbs to the parking lights and fogs. At night time, they just look like a really dull white. I hear the Lamin-X plus yellow bulb really make them stand out.
Old May 13, 2010 | 07:16 AM
Act_04's Avatar
Act_04
night time pics of that when you're done please
Old May 19, 2010 | 02:22 PM
plasticknives
I went to install the yellow fog and parking bulbs today. Passenger side went smoothly, looks a LOT better. When I got to the driver side, turns out the previous owner replaced a cracked foglight with a later style one that takes an H11 bulb, not H7
Now I need to spend another $20 on a set of H11 bulbs. I guess the positive side is I will have a replacement set if I ever need them...
Here's a comparison pic (can't really tell the difference in the fogs, but it's there)
left yellow bulbs, right clear bulbs
Old May 19, 2010 | 03:48 PM
GumbyLara's Avatar
GumbyLara
Looks good! I want to see the arch lights! Do the bulbs shine through at all? or are they just black?
Old May 19, 2010 | 04:40 PM
plasticknives
I actually just noticed today the bulbs shine around the edges, most likely where the Plastidip is thin. I think I'm just going to unplug those bulbs so there's no seeping light.
I have a concern about the h7/h11 variance though. The h7 nokya bulbs are 55/70w and the h11 are 55/80w. Do you think this 10w difference in output will be a noticeable difference in brightness?
Old May 19, 2010 | 05:42 PM
ZippyNH's Avatar
ZippyNH
Most likely not....since brightness is just like sounds, and follows the inverse square rule....something has to be 4x brighter to appear just two times as bright...so the slight wattage difference will likely be not more more than the difference between a older halogen and a newer halogen bulb....(if you look at halogen bulbs, the "brighter" bulbs, like "NightHawk" actually use a shorter filament, that runs hotter, with a shorter life...so even within a spec...h7/h11 there is some variation)....so you might be able to perceive a difference, but unless you are looking for it, I doubt you will notice it. It is more likely there will be a beam pattern difference between the newer/older lights though.....
It does look pretty cool...unconventional, but cool....no fried egg look!!
Old May 22, 2010 | 05:17 PM
plasticknives
Here are a few more pictures (will post a complete night shot once it gets dark in about an hour). A better comparison shot and a couple with the new H11 bulb. Can't notice any difference in brightness which is good.
Old May 22, 2010 | 06:41 PM
plasticknives
Night pics:
Pictures don't do it justice. They look really nice at night.
Old May 22, 2010 | 07:18 PM
DjR53's Avatar
DjR53
yay for yellow! first mod i did to my car
sevin
May 2, 2026 06:11 AM
rob&JCW
Feb 13, 2023 07:03 PM
blackie
Aug 25, 2015 09:08 PM
Emnotek
Aug 13, 2015 05:47 PM
mini yellow-haa!
Aug 13, 2015 11:18 AM
