Thinking of putting smaller tires on front? Good/Bad?
Old May 1, 2010 | 02:02 PM
xbritt's Avatar
xbritt
My 205/50ZR16 are worn out on front but rear is still very good. Goodyear doesn't make that size for EAGLE F1 GS-D3 anymore.
So, wondering, if I put 195/55R16 Bridgestone Potenza G019 Grid on the front, would there be a big problem with this?
(On a budget and would rather pay $225 for 2 than $530 for 4 if I could)
Thanks for your advise/comments in advance.
Old May 1, 2010 | 02:09 PM
ZippyNH's Avatar
ZippyNH
195/55r16 is the stock size for the S...so it will fit fine if you can mount them on your rims.
However....the different RPM's front to back may give you continuous warnings....and the DSC maybe even the braking systems might have issues....may not be worth the effort...
Old May 1, 2010 | 02:21 PM
JAB 67's Avatar
JAB 67
I don't know anyone who thinks this would be a good idea . . .
Old May 1, 2010 | 03:07 PM
NightFlyR's Avatar
NightFlyR
Years ago you could just swap out fronts and or backs, these days with all the sensors i would not even think of just replacing 2 tires, I have seen cars throw codes just replacing 1 tire, when they wear down they are turning more revs per mile, and if the difference gets too much the computer will pick it up and throw a code.
My opinion, save some $ and get 4 when you have the money
Old May 1, 2010 | 06:24 PM
xbritt's Avatar
xbritt
Ahhh, sometimes I miss my old 68 Mustang....no sensors at all...LOL.
OK, looks like swaping out all 4. Thanks for the input.
Old May 1, 2010 | 07:09 PM
NightFlyR's Avatar
NightFlyR
Yea and I miss my 68 Vette even with those loud *** sidepipes with no baffles, that car rattled more then the mini!!!
Old May 1, 2010 | 08:03 PM
RJKimbell's Avatar
RJKimbell
You are getting your 4 New Tires from TireRack aren't you??!!
www.tirerack.com
I put on the Bridgestone Potenza G 019 Grids (195/55-16) last October and absolutely L@VE them!!
Old May 2, 2010 | 06:00 AM
howsoonisnow1985's Avatar
howsoonisnow1985
It's a very bad idea and counterprodutive in terms of performance, especially with a car designed for understeer. You are better off putting the GS-D3s in the front and the Grids in the back. That way you can finish off the GYs and spare the Grids till you save another $225 and buy a new 2 Grids for front.
Or you can buy a set of 4 budget tires like Falken ZE-912 in 205/50-16 for $276 here: http://www.vulcantire.com/cgi-bin/ti...=%7Bkeyword%7D
Old May 2, 2010 | 12:50 PM
jcauseyfd's Avatar
jcauseyfd
I'm not one to replace just two tires, but those here who do will tell you the two new tires should go on the rear.
Old May 2, 2010 | 06:47 PM
earlrabbit's Avatar
earlrabbit
Why not just buy the 205-50-16 Grids for the front? According to my local tire guy who called the Bridgestone warehouse, they are just adding this size.
Old May 2, 2010 | 08:13 PM
slinger688's Avatar
slinger688
+1. This is good advise. I would just get 4 less costly tires and not upset the balance of the car.
Old May 4, 2010 | 02:35 PM
myminicutie's Avatar
myminicutie
does anyone know if 235/45/17 will fit on a 2006 MCS? i currently have 225/45/17 but would like to add some width to the tires. Maybe keep the 225/45/17 in the front and 235/45/17 in the back. Is this a good idea?
Old May 4, 2010 | 03:49 PM
howsoonisnow1985
No!
It's not a good idea!!
In case you don't know your car is front wheel drive and it's designed to understeer.
Old May 4, 2010 | 04:13 PM
myminicutie
thanks howsoonisnow1985. I appreciate your input. I'll keep my current tires
Old May 4, 2010 | 07:38 PM
howsoonisnow1985
235/40-17 "fits" with some modification to to wheel wells and fender trim.
jeremy_reyes94
Sep 6, 2019 07:53 AM
Toolman
Jan 20, 2016 06:50 AM
minipopkart
Aug 13, 2015 05:22 AM
rckrzy1
Aug 11, 2015 06:06 PM
