how much to replace an 05 mcs cooling system?
Old Apr 24, 2010 | 07:37 AM
rehgee's Avatar
rehgee
Hello I was wondering how much it would cost to replace the whole cooling system on the 05 mcs. I called the dealership and they said it depends we would need to do an inspection where it may cost you nothing, but say in all likely hood it needs to be replaced what is the cost, i have 100,000 miles on my mcs.
In addition, maybe labor prices?
thank you in advance
reggie
Old Apr 24, 2010 | 08:50 AM
ZippyNH's Avatar
ZippyNH
Going to a dealer and saying " replace the cooling system" is like going to a brake place and asking to have a brake system replaced ( some places will really stick it to you...new hardlines, new calipers, etc... ). Where do you stop? Could be thousands of dollars...some parts wear, some don't.
Why do you want it "replaced"?
Do you just want it freashened? Like new hoses, thermostat, waterpump, etc?
If you have 100,000+ miles, and do the labor on a waterpump...you might want to consoladate jobs and do a SC rebuild, or a lube...
Old Apr 24, 2010 | 08:54 AM
minilites's Avatar
minilites
Good morning try giving Danny at Minicorsa a call or check his web site
www.minicorsa.com
Old Apr 24, 2010 | 02:37 PM
thulchatt's Avatar
thulchatt
Kind of a strange question.
What is the problem and what are you trying to fix?
You probably don't need to replace the "cooling system"
Old Apr 24, 2010 | 03:01 PM
burley's Avatar
burley
There's a guy selling some cooling parts on Craigslist in Chicago. Among a few other parts, he's listing:
A/C CONDENSER - $164.25
COOLING FAN ASSEMBLY - $109.91
http://chicago.craigslist.org/chc/pts/1707719585.html
He keeps reposting them, and they've been up for a few months so I bet you can talk him down on the price if its what you need. Good luck...
Old Apr 24, 2010 | 03:08 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
I think you should figure out exactly what you need and only replace that. Asking to have the entire cooling system replaced would cost over 2k, especially since that would include replacing the heater core.
Keep it simple, it will be much cheaper.
Old Apr 24, 2010 | 07:26 PM
rehgee's Avatar
rehgee
K I see some coolant leaking and when I went under my car I saw that some coolant has sprayed under my car an has dried up, is that any better? And what I've been doing is filling my overflow tank every two weeks but sorry for my ignorance I had no idea
Old Apr 25, 2010 | 07:36 AM
ZippyNH's Avatar
ZippyNH
Just tell them you need the leak fixed...might be a $45 part...the tank, or a thermostat(similar in price), plus instal.
Never try to diagnose the problem or tell the mechnanic what to fix unless you are very sure...saying what you said is setting yourself up to be advantage of with a huge bill (thousands of $$$) for a $100 fix.
Tell them the problem...you are loosing coolant, and you have seen some dried coolant stains in x location....you don't know more...so just say you need the leak stopped. Ask for them to give you an estimate, or just fix it if it is under x dollars (pick a number you are comfortable with, like 300$), if it more, they will likely describe the problem, explain the fix, and get the ok to fix it.
Old Apr 25, 2010 | 07:43 AM
rehgee's Avatar
rehgee
Thank you so much
iggi
18
Feb 9, 2026 01:00 AM
Kimolaoha
Jul 5, 2023 01:04 PM
Khai
Feb 6, 2017 09:24 AM
Pyrs
R55 :: Clubman Talk (2008+)
19
Sep 8, 2015 01:43 PM
Red Raven
Aug 11, 2015 04:48 AM
