Drivetrain Will I hit 200WHP after tune?
Old Apr 10, 2010 | 08:52 PM
Un0RiGiNaL's Avatar
Un0RiGiNaL
Getting my car tuned by Jan on the 25th @ Mach V.
My mods:
Borla catback
Alta intake
17% pulley w/plugs/belt/tensioner stop etc
Will those three mods help me hit 200whp after a tune?
If not, what else do i need? Header? Injectors? Im on a real low budget so dont say Cam lol.
Also, With injectors, I know i can run the 380cc without a tune and anything more requires a tune. Whats the advantage of getting 550cc injectors and disadvantages? Is fuel economy worse with the 550cc injectors?
Old Apr 10, 2010 | 08:59 PM
dragonwang's Avatar
dragonwang
I think you might barely make it. My car has Invidia catback, Alta intake, 15% pulley, header, and GIAC tune and it made 200.75whp. Although you lack the header, I think Jan's custom tune will make up for it.
Old Apr 10, 2010 | 09:02 PM
Un0RiGiNaL's Avatar
Un0RiGiNaL
I also have 17% reduction rather than 15%.
I really want the DFIC, i heard a video of Webb's MINI, and his car sounds SO sick. Except the dfic costs 900$ and I dont even know if you get power from it.
Old Apr 11, 2010 | 12:38 AM
drsilvermini's Avatar
drsilvermini
550s are mainly used so if you want to upgrade in the future you dont have to buy bigger injectors, they are scaled down when the car gets tuned. I would get some injectors and a cam would help to get you to your goal. I personally don't see any benefit in getting an aftermarket intercooler, I just haven't seen people put down more horsepower on the dyno with aftermarket intercoolers
Old Apr 11, 2010 | 06:26 AM
jonnieoh's Avatar
jonnieoh
You'll probably make it, though it would depend if your car is a strong one from the factory, or a weaker one. Each MINI varies slightly, from what Jan told me.
Jan tuned me up to 201.5 whp, and I have only a 15% pulley, intake and cat-back. I'd think with the 17%, you'd potentially get even more whp than I did...
Old Apr 12, 2010 | 10:31 AM
tcscb1963's Avatar
tcscb1963
You should be close. If you ever think you are going to upgrade your head, then go for the bigger injectors as the 380's will be to small.
Old Apr 12, 2010 | 11:04 AM
davisflyer's Avatar
davisflyer
Should be in the ball park
Old Apr 12, 2010 | 07:30 PM
Un0RiGiNaL's Avatar
Un0RiGiNaL
Only other thing I have planned power-wise is a cam and headers. Should i get 440s?
Old Apr 12, 2010 | 09:37 PM
davisflyer's Avatar
davisflyer
If your on the stock head, 380's are fine
Old Apr 12, 2010 | 10:02 PM
polepino's Avatar
polepino
Possibly, I have way more mods and I got up to 229 on Jan's dyno
Old Apr 13, 2010 | 07:52 AM
tcscb1963's Avatar
tcscb1963
At least, I bought mine from Jan.
Old Apr 13, 2010 | 08:22 AM
jonnieoh's Avatar
jonnieoh
BTW, Jan told me that my car would have made more power, but I was limited by my stock injectors at the top of the rev range. So upgrading to 380's or higher wouldn't be a bad idea, before tuning.
Old Apr 13, 2010 | 08:47 AM
PorscheMini's Avatar
PorscheMini
If you will, mine should too... I have JCW Injectors, one ball, jcw intake, and a bypass valve. At least i hope so. I'm getting mine tuned by Jan the 26th at Mach V, I can't wait! Good luck reaching your numbers objective!
Old Apr 13, 2010 | 06:33 PM
Squirlz's Avatar
Squirlz
It's quite possible. As has been said some cars are stronger out of the box than others. Apparently I got a really good one! I have an Alta intake, a 15% pulley and a Volt exhaust. Also 116K miles.
I got a Mynes tune Saturday. My base run was 202 WHP! Mike and Jason couldn't believe it so they pulled it again. Sure enough, 202. After their tweaks I drove out with 210 WHP and 182 lbs/ft of torque.
My wife's car is nearly identical to mine and she got a Crower NS cam and 550 injectors installed prior to the tune. She ended up with nearly 216 WHP and 188.5 lbs/ft of torque at 4400 RPM. The cam really flattened out the torque curve and torque is what you feel. I'd rather have more torque at lower RPM than a high HP number.
Old Apr 13, 2010 | 06:35 PM
Un0RiGiNaL's Avatar
Un0RiGiNaL
Ahh did it really? I love torque. Torque is what makes the car fun..
Old Apr 13, 2010 | 09:25 PM
polepino's Avatar
polepino
On that, Jan said a similar thing about mine, that it was a really strong engine and that he was surprised I was pulling that much with the mods I had.
jetmechinnc
Nov 16, 2020 06:38 AM
ebowling
90
Aug 4, 2019 09:15 AM
TunedGP
Oct 1, 2015 04:18 PM
ki7hy
Aug 12, 2015 07:07 PM
tippin
Aug 5, 2015 08:43 AM
