brake fluid bleeding question
Old Apr 9, 2010 | 12:07 PM
tonester's Avatar
tonester
I picked up some Valvoline synthetic DOT 3 and 4 brake fluid today and I'm planning to bleed out the fluid on my MCS this weekend. I don't plan on flushing out the entire system. Since after bleeding each caliper, I have to top off the master cylinder, I'm worried about mixing the new fluid w/ the existing in there already. Is there a problem of mixing the new brake fluid w/ the existing fluid in the MCS? thanks
Old Apr 9, 2010 | 12:26 PM
Rich.Wolfson's Avatar
Rich.Wolfson
There is no problem mixing the fluid with what you have. That said I try to take out most of what is in the reservoir before I start. I use a plastic hypodermic but a baster will do if you don't want to ever use it again for food.
It's not a hard job.
Rich
Old Apr 9, 2010 | 01:45 PM
tonester's Avatar
tonester
one more thing, do you know how many bottles I would need?
Old Apr 9, 2010 | 01:57 PM
Tom D's Avatar
Tom D
I bled my O2 MCS last month, used almost a whole 32oz botle of Valvoline. Of course, your method might differ from mine but if you don't get too carried away a single bottle ought to be enough.
Old Apr 9, 2010 | 03:02 PM
cct1's Avatar
cct1
Yeah, that's a bit much. I can do mine with one bottle of ATE superblue with plenty to spare with a pressure bleeder, and those bottles are much smaller than 32 ounces.
On the other hand, once you open a bottle of brake fluid it's probably best to discard any that's leftover anyway (unless you're using it in the near future); over time, once the seal on the can is broken, it can pick up water, which is a no-no for brake fluid, so if you're using a whole bottle it's not like you're wasting anything.
Old Apr 10, 2010 | 07:32 AM
56 Blue's Avatar
56 Blue
I use an old turkey baster to suck the old fluid out of the master cylinder before starting. It saves time bleeding.
Old Apr 10, 2010 | 09:25 AM
quikmni's Avatar
quikmni
To flush the whole system should take less than one bottle. If just bleeding the brakes it will take very little fluid.
Old Apr 12, 2010 | 02:49 PM
JeffM's Avatar
JeffM
I think you could do brakes only with 1 pint, but it's safer to buy two (and it's cheap stuff). I did the brakes and clutch this weekend and used about 1.5 pint bottles, being very thorough and making sure I was getting good clean fluid at each bleed point.
Old Apr 14, 2010 | 01:51 PM
apexer's Avatar
apexer
Thats one of the benefits of using Ate brake fluid. You can alternate between Superblue and 200 (amber in color) so you know when you have a good flush without wasting fluid. One bottle should be enough.
minimofo
Apr 4, 2016 07:36 PM
minimofo
Dec 26, 2015 11:45 AM
Redhotz
R55 :: Clubman Talk (2008+)
Aug 14, 2015 05:29 AM
