Could you recommend on Wheels?
Red cooper (white roof).
The originals are too pricey (web and crown spoke are amazing).
Would like an upgrade to 17", web spoke/crown spoke like, silver.
Please recommend company & style.
I'm happy with my Rota Slipstream 16x7 wheels. The 17x7.5 are currently on sale for $159 ea., but only available in bronze, flat black, or white from Fast MINI. They may be able to custom order silver. Or, they may be available elsewhere.
I had a set of Rota RB 16x7 that were damaged in an accident, and went to Slipstreams because they are lighter, and easier to clean.
I started out with heavy (22.5 lbs) factory 17x7 Crown Spokes, but sold them for lighter-weight CenterLine RPM 17x7 that only weigh 16 lbs. They are raw aluminum, so require a fair amount of care. They are not finished as well as the Rota wheels. Also, CenterLine has an F rating with the BBB for poor customer service. Otherwise, I haven't had any problems with them.
16" wheels tend to be lighter weight, and provide a softer ride. Many racers prefer small wheels because of the unsprung weight advantage, others like larger wheels for the quicker turn-in. Mostly, large wheels are for looks over function. I tend to like the smaller wheels.
Not sure about the crown spokes but the Web Spokes are a MINI only design. I have looked and looked to try and find something similar and not found anything anywhere. I wanted some for use as winter wheels but ended up with something else because of price.
Wow, thanks.
Now I'm aware of other stuff I wasn't such as:
1. Weight - Especially that wider tires will cost me in performance and fuel consumption.
2. Finish (easy care).
3. Get wider rims and stay with 15-16" (good for comfort ride).
btw,
crown spokes replicas:
http://www.wheelsandcaps.com/w_selec...ER&_MODEL=MINI
Although I'd prefer a well known company.
The cooper's original are nice looking but too narrow (5.5?).
btw,
Common places to look are Tire Rack and Discount Tire Direct. You can Google wheels and get many dealers. Is your car an "S"? If so not many 15" wheels fit your car because of the brake calipers and also the rear contol arm gets in the way. The control arm is a factor on base Mini's. I know because I have been extensively researching and looking for 15 inch wheels that look good. You can add 195/60/15, 205/55/15 tires or 215/50/15 tires for a real good look. These will also fit on 5.5 inch wheels and up. On a base Mini weight will affect acceleration. I'm having difficulties finding the "right" wheels. I currently have 15" Mini Spoolers and am considering just adding wide tires. It could be a unique look. The choices are few and far between. Hope this helps.
BRX510 or others, I have the factory 17in web spoke that I am willing to sell cheap since they are used and abused. I know a guy that would refinish them if you were intrested but I dont want to fix them up if your not. I am only going to ding them up again, that is why I wont fix them up for my self, and I need to get some blacked out rims to go with the blacked out car. I can send pictures if you are intrested. They are not posted in market place do to, I'm not sure what I want to do yet, but if really want them let me know.
Lighter wheels will give you a better ride because there is less mass for the suspension to absorb when a wheel hits a bump. Braking and acceleration will be a little better because the wheel will have less inertia (this is probably a subtle difference).
, but I don't live by.Nope. Non-S Cooper.
Next time I'll replace mine.
I went through numerous companies, the options are endless.
I still haven't found ones that are prettier than the web-spoke (which I wouldn't go for anyway , as they're heavy and 17"!).
Tiretrack gives an option to see the rims on the car and it's very helpful.
1. Size: 15" or 16", I tend towards the 15" so I could have more comfortable ride, but still 16" might be prettier. The original 175/65 are great for that matter.
15" with wider
2. Tires: preferably 205/65. But I guess that it might be ugly - 205/65R15...
So 205/60, 195/60, 205/45, 205/55, 205/50 might the options.
Now go figure what will preserve my comfort ride (as it's important to me), look great and give.
3. Tires make and type - numerous options.
4. Weight - the lighter the better. Mine is 13.7lb.
Of course I'll appreciate more advices and pics.
Good know I don't have to prove they fit. I know the bolts fit though those rims, with my 12mm lug bolts theres alot of room.
205/65 and 205/60 aren't matches to the original 175/65/15's diameter. The 195/60, the 205/55 and a 225/50 are. I don't find the options for 15 inch wheels endless. Be sure you specify the year and make of your car. Don't just go under 15 inch wheels as many do not fit. Tire Rack for example only has about 8 wheels that fit in the 15 inch size. I find the selection to be poor. Discount Tire isn't much better just different colors and varieties of the same wheel are shown. I know there are other distributors but the names of the wheels are those I don't recogonize. Of course the 16 inch adds some options. Good luck.
Kimolaoha
Dec 5, 2020 09:32 PM
thebordella
Aug 31, 2015 01:37 PM
brother i
Tires, Wheels, & Brakes
Aug 23, 2015 01:15 PM
Aug 21, 2015 11:25 AM
sabjcw
Aug 14, 2015 07:40 AM
