Drivetrain Conflicting research: oil pressure sender 3/8 NPT or M16x1.5?
Old Mar 26, 2010 | 09:46 AM
plasticknives's Avatar
plasticknives
I'm trying to figure out whether the oil pressure sender port on the block is 3/8 NPT or M16x1.5. I've read conflicting information and want to be sure before I order anything. Thanks.
Old Mar 26, 2010 | 09:59 AM
Partsman's Avatar
Partsman
Legion_of_Doom
3/8 NPT
Old Mar 26, 2010 | 12:55 PM
fishead # 1's Avatar
fishead # 1
npt vs met
I guess as a plbg cont for a LONG time I'll stick my 2 cents in. Yes 3/8 npt works------right------no. The metric is correct but is"interchangeable" w /npt. NPT (natl pipe thrd) IS tapered--the "pitch" on the 16mm is REALLY close & vice-versa and a couple other sizes will "exchange" also. The "COOL" thing to do w/ the oil sending unit itself is to mount it remotely as it does NOT like being "abused" (vibration etc) so you come out of the port w/ an adaptor 3/8 npt x 1/4" FLARE then pipe/ tubing to a more "stable" or insulated locale. Mount the sender there (another adapt) then pipe /tube out to the gauge. The sender will now last like forever !! And "IF" it goes bad you can get to it .Two-1/4" flare nuts & two 3/8 x 1/4 fl adapts some tubing & a flaring tool. DON'T use compression as it WILL come apart eventually and thats NOT a good place for that "occuring"
Old Mar 26, 2010 | 04:00 PM
plasticknives
yea I plan on remotely mounting it with -4an stainless line. This is what plan on doing:
Block > 3/8m to 1/8f > 1/8m to -4an m > 3ft -4an hose > -4an m to 1/8f > 1/8m to 1/8m > 1/8f to 3/8m > 3/8 T w/3f > stock pressure sender on one and aftermarket sender on another with 3/8m to 1/8f
Old Mar 26, 2010 | 04:27 PM
fishead # 1
sender
Purrfect !! Also-YES--BLEED / purge the line----it doesn't say "air gauge" eh !!
Old Apr 3, 2010 | 12:39 PM
plasticknives
Finally got it all hooked up. I extended the stock sender wire and zip tied it to the braided line to prevent it from touching the exhaust manifold. This was the best location I could find for the T and 2 senders. It's wedged in there pretty firmly, I don't think its going anywhere.
Conflicting research: oil pressure sender 3/8 NPT or M16x1.5?-qkhpf.jpg
Old Apr 3, 2010 | 12:47 PM
fishead # 1
d-re-root
That IS a good safe lookin / easily accessable job------you won't be sorry ! Did you just "pod" the gauge or???
Old Apr 3, 2010 | 01:24 PM
plasticknives
Custom dual pod mount
https://www.northamericanmotoring.co...e-install.html
Kimolaoha
Jul 5, 2023 01:04 PM
TREX
Nov 2, 2019 07:31 PM
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
Emnotek
Aug 13, 2015 05:47 PM
