Something Doesn't Smell Right
Old Mar 25, 2010 | 06:25 PM
Mateo_Feo's Avatar
Mateo_Feo
So hey guys looking for some quick assessment help before I go to the mechanic. My mini was running fine, when I noticed I couldn't hear the SC whine anymore, turned down the music and then the car sounded like it was dieing, then the check engine light went on, the traction control light went on I mean the display lit up like crazy. So I threw it in neutral and pulled off. Got it towed back to my place. Started the car when I got back, it drove forward and backward, but then I noticed a smell coming the engine. I didn't hear the whine either. Is this a blown supercharger?
My mini is an 05' S with a 17% pulley.
Old Mar 25, 2010 | 07:28 PM
plasticknives's Avatar
plasticknives
Release tension from the belt and spin the pulley.
Old Mar 25, 2010 | 07:36 PM
miniola's Avatar
miniola
What's it smell like? Burning rubber or what?
Old Mar 25, 2010 | 08:37 PM
MINIdave's Avatar
MINIdave
Check your crank pulley too...
Old Mar 26, 2010 | 05:52 AM
BlimeyCabrio's Avatar
BlimeyCabrio
I'll bet $1 it's a failed crank pulley.
https://www.northamericanmotoring.co...-gone-bad.html
I just replaced mine a few weeks ago after a similar failure. I went to the ATI Super Damper so it won't happen again.
Old Mar 26, 2010 | 07:03 AM
Helix13mini's Avatar
Helix13mini
Okay, for fun I'll take the $1 bet (payable at the Dragon). I think Mateo has a failed supercharger. I hope for Mateo's sake that BlimeyCab is right and I'll be paying him US cash currency, since a crank pulley is a lot cheaper than a supercharger.
Mateo:
Look carefully at your belt. Is it still sitting as it should on the various pulleys? If so, is it scored and scratched up on the back side? I suspect not. See if you can get your hands on a belt tool and remove the belt from the supercharger pulley (search around NAM for instructions). Try moving the supercharger pulley by hand. If you can move it at all, and it seems pretty smooth as it turns, you're in luck, and inspect the crank pulley as Blimey suggested. You won't be able to turn it, so get a mirror down there and inspect it for damage to the rubber part in the center. You can also remove the front passenger's wheel and wheel arch liner for a better look. Still stumped? Contact me and I'll instruct you further.
Old Mar 26, 2010 | 08:02 AM
BlimeyCabrio
yer on.
Old Mar 26, 2010 | 09:47 AM
Mateo_Feo's Avatar
Mateo_Feo
Well not are how to describe the smell it just didn't smell good. It could have been rubber. Because I mean I've smelled the smell before haha, not from my car, so it was familiar. Just not enough to be sure how to put it.
Thanks for the suggestion Blimey and Helix. I'm going to rent an OBD reader, or borrow one if I can in few. Then when I get back I have a tensioner tool. I'll check the pulley's. I really hope it's the crank, at least it'll be cheaper then a new SC. If after that I can't figure out I'll use the reader.
Keep you guys posted. Thanks again.
Old Mar 26, 2010 | 10:24 AM
Mateo_Feo's Avatar
Mateo_Feo
Okay so I started the car again to get a good listen. It definitely smells like rubber, and it's really strong in the passenger seat. The noise sounds like a cranking clicking sound, but when I put my ear near the supercharger while it was turning it didn't sound like it was coming from there. So it looks like it might be the crank. If so it'll be a couple of weeks before I fix it. Meantime I'll probably try to prop the car up and get a better assessment tomorrow. Thanks again for the help guys. Any other advice I'm all ears. Keep you kids posted.
Old Mar 26, 2010 | 12:54 PM
minirooferS's Avatar
minirooferS
its probably your belt if you smell rubber, but who knows. Im FAR from an expert. I really doubt your S/C went.
Old Mar 26, 2010 | 02:37 PM
BlimeyCabrio
the crank pulley damper is also made of rubber. And makes a nice burning rubber smell when it disintegrates.
Old Mar 26, 2010 | 04:19 PM
miniola's Avatar
miniola
Exactly what I was thinking... that's why I asked about the rubber smell first. It can be hard to tell if it's the pulley for sure though because it can disintegrate inside first without exterior signs.
But my vote is for the pulley.
brads2002
Oct 14, 2015 06:53 AM
Juan Baddoggi
Sep 24, 2015 06:34 AM
mini_mike237
Sep 21, 2015 08:42 AM
RocketUSA
Sep 15, 2015 07:45 AM
Sep 2, 2015 09:05 AM
