R50/53 Tail light issues
Old Mar 23, 2010 | 03:10 PM
CRoth's Avatar
CRoth
Tail light issues
I have an 04 MCS and the top bulb on both tail lights doesn't work. I've checked the bulbs and their both fine. When the headlights are on the bottom of the three lights is on. The turn signals (middle light) work fine as well. Can anyone suggest a possible solution or a way to diagnose this problem? Thanks in advance for the help.
Old Mar 23, 2010 | 04:18 PM
DAVESTER's Avatar
DAVESTER
The top bulbs are for the rear fog lights and have to be programed by the dealer. However, if you do a search for 1st gen.tail light Mod., you can make the top bulb work with the lower stop light very easy--- I did mine!
Old Mar 23, 2010 | 04:30 PM
CRoth's Avatar
CRoth
I just got done reading about that on another forum. Thanks for the info, I will chech that out. I hate it when something doesn't work on my car! Lol
Old Mar 23, 2010 | 04:35 PM
CRoth's Avatar
CRoth
I did a search for 1st Gen. Tail light mod. And came up with nothing. Do you have any more leads? Thanks
Old Mar 23, 2010 | 04:44 PM
DAVESTER's Avatar
DAVESTER
go to # 7 post and open tail light mod with diode
https://www.northamericanmotoring.co...ification.html
go to Radio Shack and to get the diode
Old Mar 23, 2010 | 08:10 PM
04Mini-S's Avatar
04Mini-S
Or if you want, you can just switch wires 1 and 4. The fogs will now be the brake lights and the lower will be just the running lights.
https://www.northamericanmotoring.co...n-signals.html
Check out post #19.
Old Mar 24, 2010 | 01:44 AM
CRoth's Avatar
CRoth
Thanks for all the help! I'm going to try this after work today, I'll let you know how it turns out.
Old Mar 24, 2010 | 06:48 AM
CRoth's Avatar
CRoth
I tested it with a paper clip bridging 1-4 and it worked great. I'm going to install a jumper wire on both later. Thanks again!
Sexual Chocolate
Mar 31, 2019 08:02 PM
dyeLucky
Sep 11, 2015 10:41 AM
cm.d
Aug 19, 2015 08:51 AM
messyjesse96
Aug 12, 2015 05:51 AM
